Possibly messed up Opti
Old Feb 29, 2004 | 03:48 PM
IDOXLR8's Avatar
Unhappy Possibly messed up Opti
I was bypassing my coolant hoses from my heater core and accidently hit the opti with some coolant. Is there any way to clean the terminals from the opti? Also I am running an LTCC box. From my understanding the opti is mainly used as for a cam signal. If the terminals got wet is that going to affect the low res from the opti? THanks in advance.
Old Feb 29, 2004 | 04:26 PM
TransAmGT's Avatar
Just let it dry...have you run the car yet? Also what year is it...if it's a 95 or earlier you should be fine! It's them 93 and 94's that suck when you get water in them!
Old Feb 29, 2004 | 04:32 PM
IDOXLR8's Avatar
Actually mine is converted over to a 95 stlye opti. I have not started the car because the car currently is apart.
Old Feb 29, 2004 | 09:04 PM
SloLt1Z's Avatar
Quit being a wus, it's fine
PS Z vs Z @ Norwalk?
Old Mar 1, 2004 | 09:55 AM
IDOXLR8's Avatar
You better hope the opti is messed up
Old Mar 1, 2004 | 01:47 PM
SloLt1Z's Avatar
Or that you don't get off your *** and buy slicks, and I do.
Old Mar 1, 2004 | 02:21 PM
IDOXLR8's Avatar
Like I said don't worry about my car. The slicks will be on my car come Norwalk. How many times do I have to tell you BNs. When I say I am going to buy something I will. Better hope your bracket makes it back on time.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
BLK1997Z28
May 7, 2015 03:01 PM
grabbem88
Mar 18, 2015 01:25 PM
Sparky
Sep 6, 2002 11:41 AM
