Possible valvetrain problem?
Old May 28, 2007 | 12:25 AM
  #16
JP95ZM6's Avatar
Originally Posted by Ricardo
There have been a lot of posts regarding the GMPP Guideplates wearing out real fast due to not being hardened.
I myself experienced some wear in a set after about 4000 mile use.
I found that the trickflow guideplates for the LT1 heads have the same spacing and are hardened.
RG
Would that be these Trickflows?
http://store.summitracing.com/partde...32#Application
Old May 28, 2007 | 12:29 AM
  #17
wrd1972's Avatar
RG
Like this:
http://web.camaross.com/forums/showt...highlight=hell
Old May 28, 2007 | 12:23 PM
  #18
Ricardo's Avatar
Yes, those are the ones.
TFS 30400623-8
RG
Old May 28, 2007 | 09:35 PM
  #19
JP95ZM6's Avatar
Great - thanks, Ricardo. That's what I got. I'll be putting them on shortly - I'll post feedback here if any problems occur.
Old Jun 3, 2007 | 11:04 AM
  #20
JP95ZM6's Avatar
Feedback: The above trickflows I referenced fit great on my stock casting LE2 heads. Rockers are centered on valve tips. About .014 pushrod-to-guideplate clearance with Comp Hi-Techs. That's enough to let the rocker pivot so either edge of the roller can slide over to barely hang off the edge of the valve tip when the rocker is twisted on the stud. But .010 is a lot less than the .025 acceptable clearance I have seen referenced here.
HectorM52
Jul 30, 2017 11:46 AM
69z-28
Jan 29, 2016 10:46 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
