possible to raise the compression to 11:1 using stock pistons?
Old Jan 22, 2005 | 11:11 PM
Pasky's Avatar
Can you run a thicker head gasket to get a 11:1 compression ratio on a stock bottom end? If so, what size do I need to run? Thanks?
Old Jan 23, 2005 | 12:02 AM
redcamaroz28's Avatar
Re: possible to raise the compression to 11:1 using stock pistons?
Not thicker, thinner head gasket. I got an even 11:1 compression by using the .029 Impala head gasket (.049 stock).
Old Jan 23, 2005 | 12:32 AM
chevyguy3's Avatar
Mr Gasket #5716. .026" compressed, and is cheaper and seals much better on aluminum heads than the Impala gasket
Old Jan 23, 2005 | 12:39 AM
Nick-LT1's Avatar
how much would that help? would it still run fine on 93 octane?
Old Jan 23, 2005 | 12:43 AM
Pasky's Avatar
Cool, thanks. Im going for more cam, so I imagine more compression helps a cam more, you want less for forced induction.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
pimpss96
Feb 12, 2015 01:28 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
