Is it possible to pull the heads without draining the block?
Old 04-06-2003, 08:56 PM
94 CAMRO Z28's Avatar
I have the radiator out and everything up front is drained. With my ypipe/offroad pipe setup that I have now, its gonna be damn near impossible to get the Ypipe out of the way enough to get at these drains. So is it possible to pull the heads without doing it or am I going to flud the cylinders with coolant? Thanks
Aaron
94 CAMRO Z28 is offline
Old 04-06-2003, 09:01 PM
94F1Z28's Avatar
I pulled my heads without using the drain plugs on the block and i did get some coolant spilled in the bore but not that much.
94F1Z28 is offline
Chris Anderson
01-27-2015 08:30 AM
D1SC383LT4
01-26-2015 01:41 PM
Sandersen511
01-13-2015 03:49 PM
Catmaigne
12-25-2014 12:16 PM
thenewkid
11-27-2014 09:41 AM
Quick Reply: Is it possible to pull the heads without draining the block?
