possible power?
Old Aug 17, 2006 | 06:08 AM
vatechguy3's Avatar
possible power?
if building up a new lt1 4 bolt block, how much power is possible?
i know a major variable is how much money is spent, but just curious if an lt1 can be built with comparable power to an ls1 motor???
thanks
tony
Old Aug 17, 2006 | 01:22 PM
chads97z's Avatar
Re: possible power?
I have 485RWHP on a ALL MOTOR LT4 - like you said.. how much $ do you have...
Old Aug 17, 2006 | 02:44 PM
OrbitalChris's Avatar
Re: possible power?
I have not een 400hp and I can pull off mid 11s, a few thousand well placed bucks will get you there
Old Aug 17, 2006 | 03:41 PM
Re: possible power?
I've seen a stock 4-bolt LT1 block (with upgraded caps) with no fill, make 1,125 flywheel HP on a blown 383 running 20+ # of boost. And it ran that way for a couple years with no problems.
Old Aug 17, 2006 | 05:09 PM
EKO's Avatar
EKO
Re: possible power?
Wow that is impressive!
Old Aug 17, 2006 | 09:31 PM
vatechguy3's Avatar
Re: possible power?
ok, 1125hp is a little more than i am looking for!!
i would like 500-600 when all is said and done. and i know that means building a new motor from the ground up. and actually, that is better because i can still drive the car while i'm building the motor!!
so how much money, ballpark estimates, to get that much power??
thanks
tony
Old Aug 18, 2006 | 12:40 AM
HardcoreRM125's Avatar
Re: possible power?
At least 10,000 if not significantly more. Will be going all motor? Nitrous? Turbo/Super ?
Plan on spending ALOT of money.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Keenan
Jan 19, 2023 12:24 PM
DarkKnight
Exhaust System
19
Oct 17, 2016 10:28 AM
NewsBot
May 16, 2015 03:40 PM
XtremeLt1
Sep 13, 2002 08:50 PM
