possible opti problem?
finally got car running after the heads and cam install. but now the car wont idle when the car is hot. it will start and idle but it wont stay running once ive started driving it. also it feels like its misfiring at high rpms. could it be opti? thanks again in advance for any help.
Re: possible opti problem?
Did you set "0" lash during the install? Also sorta sounds like a valve spring issue aside from the fact that it only happens in closed loop. How about the o2 sensors? Are they working properly? Do you get an SES light when this happens?? If ya do and its DTC 16 for example, than its the opti.
grabbem88
Mar 18, 2015 01:25 PM
Alex Barnes
Jan 24, 2015 10:21 PM
