POS only ran a 15.2@93mph wtf????
Re: POS only ran a 15.2@93mph wtf????
mabe its a v6 with z28 badges? lol jp but my car has 2.73 and it shifts right at the line mabe a little after it, but it also traps 103 ish. 180k = lots of worn parts id check compression, mabe u got a bad valve spring or a bent push rod or somthing. but one time i did have bad plug wires and it was a real dog till i changed them, went from a 13.8 w/ a 2.3 60ft to a 14.6 with a 2.3 60 ft, give it a good tune up and see how it feels
Yeah, back when my car was a stock 2.73 auto, it would run 14.4 @ 97 and that was in second gear. Hell, the trans would loose 3rd and 4th gear periodically and I would still go to the track, just keeping it locked in 2nd, lol. 2.73s stink.
Finally someone with a higher mileaged car then me!
. But my 2.73's shift at 90-93 miles an hour. Check to see if you're shifting at 5700-5800 RPM, cause if it's going all the way to the rev limiter at 6200 or what ever stock is then you have a faulty tranny and that could also cause some slower times.
Originally Posted by Warlock1313
I thought as much, but there isn't a need for a dyno yet
how many miles does yours have sin???
The newest (replacement) LT1 longblock put in this car was about 13,000 miles ago...most recent tranny was about 2,000 miles ago. Since then I have added Kook's LT's and a cutout...she now hits 14 flat with a ****ty 2.3 60ft but traps 102mph (compared to stock 97mph)
182 THOUSAND miles.
Weak valve springs, low compression.
no motor lasts forever.
I am betting if you check those two will be a big part of the problem.
Mine has 160k on it and with the mods I have it should be running 12s.....but the best the old LT1 can do is 13.4.
Faster than yours but it gets slower every year, even though its kept in top tune.
Check all the basics for sure but I am afraid tis time for a rebuild if you want the most performance you can get.
Originally Posted by revtime
182 THOUSAND miles.
you cant start doggin on a car (especially a high mileage one) when its not in good running condition!
your opti could be shot or on its way out, same with the coil/ICM and fuel pump (stock GM pumps are junk)
also, stock coil wires are known too go bad
have you pulled any plugs?
diagnose whats wrong with it, then fix it and go back too the track
I'd ditch that LT1, sounds like you got a ****ter! I've got a 95 with 101K, LPE CAI, Hooker cat-back and 3.73's running 13.7 at 99mph. With those times something is seriously wrong though, just rebuild to a 383ci
Toole
. Toole
will do a comp test tommorow.
what about timing chain slack-these cars must have atleast 60k+ on them.
Also I am wondering if it is because of the newer fuels and bolt on mods that is creating an insufficent spark problem?? (hesitation on accel -idle to WOT)
seems to be a common problem alot lately
I used my snap-on scanner and found everything appears to be in spec
