POS only ran a 15.2@93mph wtf????
Old Aug 12, 2005 | 07:02 PM
Warlock1313's Avatar
Angry POS only ran a 15.2@93mph wtf????
I think I should have stayed with my fords this z28 is slow as hell.
2.460ft -no tire spin
6.660 -330ft
10.09 -1/8 mile
15.2@93mph
this thing needs help any ideas??
Old Aug 12, 2005 | 07:04 PM
cas0484's Avatar
Re: POS only ran a 15.2@93mph wtf????
Those are horrible times, how is the car running? Is it throwing any codes? How many miles? Has it been recently tuned up? It could be any number of things making that car a dog but something is def wrong. Need more info.
Cmr0z28's Avatar
Maybe that 330' is telling you to get rid of the car.
Old Aug 12, 2005 | 07:10 PM
marshall93z's Avatar
LOL! Yeah, really!
Old Aug 12, 2005 | 07:25 PM
it doesn't start pullin till 3k ,hesistates off the line. It is the same if I leave @1500 (approx.) rpms or I just stomp the pedal from a stand still.
the car has the following:
182000 miles on the clock
flowmaster cat back
underdrive pulleys
bbk t/body
new trans (auto)
K/N fipk
gutted cat
plugs ,wires, fuel filter, and opti replaced 2yr's ago
no codes present
Old Aug 12, 2005 | 07:29 PM
JP94Z's Avatar
Yikes. Yeah, that is slow. Not right kinda slow. Any rough idling? Arcing wires? Trouble codes? Smoke?
Old Aug 12, 2005 | 07:32 PM
it runs a lil rough at idle but I have seen worse, no smoke ,checked wires last night in the dark none arcing. It goes into third gear at the traps btw.
Old Aug 12, 2005 | 07:41 PM
ZMAN Z28's Avatar
I take it is an auto. Some of the auto's had 2.7? gears. You might have crappy gears. Do you have a way to scan it to see if the o2's or any other issues don't seem right even if it isn't throwing any codes. You said it had 160 or 180k miles on it. I'd check compression. Throw some new plugs in it.
ZMAN
Old Aug 12, 2005 | 07:52 PM
JP94Z's Avatar
As far as the shift to 3rd goes, if it's the 3.23 rear at the stock shift point of 5700rpm (with stock tire diameter) would come at roughly 81-82mph. With the 2.73 gear @ 5700 would be more like 103mph.
Maybe check for vacuum leaks and double check the condition of your plugs and wires. Sounds like you're saying it's weak down low but catches and then pulls fine from 3k up?
Old Aug 12, 2005 | 08:02 PM
it has no power down low. shouldn't it be in third gear b4 the traps even with 2.73's??
Old Aug 12, 2005 | 08:39 PM
JP94Z's Avatar
I'm pretty sure I've read a post here, or even someone's signature, that had 2.73s that said it was still in second. Hopefully someone with 2.73s will notice this and chime in with their experience.
I'd do the basics first, checking for vacuum leaks and trying to find signs of arcing. I recently found some arcing of my wires right where they snake around the accessory bracket, very hard to see. Maybe even double check the TPS adjusted correctly.
Old Aug 12, 2005 | 09:28 PM
Cmr0z28's Avatar
No 2.73 F-bodies should be going through the traps in 2nd gear...
Old Aug 12, 2005 | 11:05 PM
then I am going to need 4.11's
Old Aug 12, 2005 | 11:29 PM
94sinister's Avatar
6.660 -330ft
10.09 -1/8 mile
15.2@93mph
Wow even my freakishly slow LT1 runs faster than that. My 94 Formula, A4 2.73 gears ran a 14.6 @ 97 with 2.3 60' stock...granted that was here in AZ with 2300 altittude and it was about 100 degrees outside at 10:00 PM.
-There is definently something wrong with your car...NO LT1 should be running that slow of times. I personally would take it to a local performance shop and throw it on the dyno, have em hook it up to a wideband and see what's goin on
Old Aug 12, 2005 | 11:31 PM
I thought as much, but there isn't a need for a dyno yet
how many miles does yours have sin???
