porting throttle body?
Old Jan 21, 2004 | 09:05 AM
ppmz28's Avatar
I am interested in porting a throttle body, about how much does it cost and is it worth? Should I go to a 52mm? I have a 94' z28.
Old Jan 21, 2004 | 10:14 AM
QCKZ28's Avatar
a bigger throttle body is not needed on a bolt-on car. i would look for power elsewhere.
what other mods do you have?
jesse
Old Jan 21, 2004 | 10:22 AM
Brundle's Avatar
i thought getting up to a 52mm TB would help a bit cause the ports on a stock intake manifold were 52mm wide
Old Jan 21, 2004 | 10:25 AM
Bastardcat's Avatar
I agree, a bigger TB at this point would probably do you little to no good.
(To help others assist you, post your year model along with all your mods in your signature field under your profile. )
QCKZ28's Avatar
the 48mm TB flows enough air for stock/bolt on cars.
by upgrading to a 52mm, you would gain less than 5rwhp.
jesse
Old Jan 21, 2004 | 10:30 AM
Bastardcat's Avatar
The stock TB is probably not a source of restriction for you at this point.
Old Jan 21, 2004 | 10:40 AM
Brundle's Avatar
so just out of curiousity, when is it neccessary then to get a bigger TB?
forced induction? n20?
Old Jan 21, 2004 | 10:56 AM
QCKZ28's Avatar
this topic is debated here frequently. do a search.
IMO the stock Tb is good enough for 375rwhp, then you can start thinking about upgrading.
jesse
Old Jan 21, 2004 | 12:09 PM
ppmz28's Avatar
there are my so far mods.
Old Jan 21, 2004 | 12:41 PM
lt1g3n's Avatar
I would definately worry about getting power from something else... stock cam? stock heads? injection? inside of your motor bone stock ? sounds like you don't have much done on your motor... i'd start getting some parts
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
Jul 4, 2005 05:00 PM
