Porting intake for larger throttle body...
Old Dec 7, 2004 | 09:51 PM
Myxtreme1's Avatar
I will not have the larger throttle body when I reassemble the motor, should I still port the intake since it's off the motor right now? I don't see what it would hurt to open it up. I will be going with a 58mm tb so should I port it right about that much? How do I get the shavings out of the intake when I'm done?
Old Dec 8, 2004 | 05:02 AM
Myxtreme1's Avatar
Re: Porting intake for larger throttle body...
anyone?
Old Dec 8, 2004 | 09:19 AM
SVWHAT's Avatar
I did mine. It will not effect anything since the throttle body is smaller then your new openings you will not notice a thing. You might as well gasket match the runners while your at it. To clean it brake cleaner compressed air I suppose.
Old Dec 8, 2004 | 09:29 AM
Flyin_Z28's Avatar
I'm running on a 58mm on my intake with stock throttle body till I get something bigger. Car runs fine. I cleaned my intake with gasket remover "Permatex". That stuff takes off anything.
QuickSilver02
Apr 7, 2015 11:12 AM
edman
Jan 22, 2015 02:45 PM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
