Ported vs Stock LT1 heads
Old May 26, 2004 | 01:07 PM
StumpDeisel's Avatar
Heyas all. Trying to determine the best bang for the least buck for my LT1. I have a blown head gasket, so I'm definitely putting a CC305 or hot-cam in along with a set of shorty headers (need to keep the car emissions legal). My question is, with this type of cam, how much more HP can I expect using ported heads compared to just a 3-angle valve job on my stock heads?
3-angle valve job and prep of stock heads= $375
Used ported heads = $800 (current deal I was offered for a pair)
Money is tight, so I need to determine if it's worth it for me to spend the extra $425 on the heads, knowing if I sell my stock heads that could cover some of this extra cost...
Thanks in advance for the input.
Old May 26, 2004 | 01:14 PM
SS MPSTR's Avatar
The power is in the heads. The cam alone is worth only 35-40rwhp on a stock set of castings. HP costs money my friend. How fast do you want to go? = How much money do you have to spend?
Whether the heads would be worthwhile depends on the work done to the heads. I've seen crappy 'port' jobs yield minimal results, and I've seen killer port jobs yield tremendous results. Get them flowed before you purchase them.
Old May 26, 2004 | 04:05 PM
TenaciousZ's Avatar
I'd recommend getting those lt1 heads ported, you'll be glad you did. I also broke the bank on my head swap. Now I need brakes I also traded my stock heads for a set of fms 30# injectors
Old May 26, 2004 | 04:07 PM
Mindgame's Avatar
Port em dude!
Always wanted to use that one.
-Mindgame
Old May 26, 2004 | 04:11 PM
91RSLT1's Avatar
I would go ahead and do it now while the heads are off. You will just kick your self in the a** later for not doing it "right" the first time. Also consider if you really want to do the head swap again, you know you will want more power later. Oh and to answer your question, definatly get them done, horespower is in the heads like SS MPSTR said. Enjoy the cam and hopefully heads.
Old May 26, 2004 | 04:26 PM
Thx all for the input. Doing some research I found I can get a few hundred for my stock heads, so it's definitely worth it...
I laugh at myself cause I went through this w/ my 86 TA, once you get that HP bug, the itch keeps growing the more you scratch it lol. I wish they had pcm programming in '92 when I put 58cc vette heads and a 268 solid roller in a 355 w/ the stock tpi on it. It never ran its full potential because pcm tunes were few and far and very expensive...
T/A lt1's Avatar
Just send your heads to Lloyd Elliott for $600 and that will save you the hassle of trying to sell yours and you would have an awesome set of heads. It's only going to cost $225 more than the $375 and you won't have to tear the engine down later to get the heads done. Later
Old May 26, 2004 | 04:31 PM
I was actually looking at the AI econo-port for 495, but I would still need additional work done. I'd rather find a deal for used ported heads and bolt 'em on, then sell my stockers to recoupe some costs. I have a line on a fairly fresh set complete w/ springs, guideplates, and ARP stud set for $800 flowing 239 @ .550 / 254 @ .585...seems like a good deal.
Old May 26, 2004 | 05:10 PM
TenaciousZ's Avatar
I paid $600 for heads that flow 262 @ 500 lift with CC10308 springs. for that price the flow numbers seem a little low.
Old May 26, 2004 | 05:29 PM
LT1ponykilla's Avatar
If you look on AI's site his Econo's usually flow around 270-275. Thats what Im going with here in the next month or so. I will hopefully be in the 370-380rwhp range.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
Brian-94TA
Jul 31, 2002 02:52 PM
