ported lt4 heads and WHAT CAM?????
Old Aug 26, 2003 | 02:54 AM
Dans91's Avatar
Ok, what i thinki will do is put on the ported lt4 heads and intake, but i dont know what to run as far as a cam right now. What cam would make the best power with this set up on my car. Looking for really good track time plus great rwhp. I thought the hot cam would go good, but guessed wrong. Any help would be greatly appreciated.
Thanx
Dan
Old Aug 26, 2003 | 04:09 AM
atljar's Avatar
GM 847 will give 400+ rwhp assuming you have a well running car and a decent head porter
Old Aug 26, 2003 | 11:32 AM
Dans91's Avatar
is that the part number and am i same running that one with the stock bottom end??
Thanx
again.
Dan
Old Aug 26, 2003 | 01:09 PM
atljar's Avatar
GM part = 12370847 .
Yes, thats on the stock bottom end, expect to sping some high rpms to put down the power however. There are only 4 or 5 of us running it on this board, but we are all putting down some very nice numbers
Old Aug 26, 2003 | 01:19 PM
atljar's Avatar
Also forgot to mention, that is still a very streetable cam. If you are going all out, solid roller will make more power, but i would never run one on a mostly street car.
Old Aug 26, 2003 | 09:53 PM
kgkern01's Avatar
Just wondering, how does the GM 847 compare to the CC 306?
Old Aug 26, 2003 | 09:57 PM
LimitedEd1LE's Avatar
I would go with the CC306, the Comp Cam 224/230 XE, or the Comp Cam 230/236 cam. If you want hp and streetablilty go with one of these. The 230/236 and cc306 are very agressive cams that are known to lay down some hp.
Old Aug 26, 2003 | 09:58 PM
xxsaint69x's Avatar
CC306 GM 847
j/k
GM847 has higher lift the the CC306, but they are pretty close i suppose. Pretty much putting down same times.
My time in the sig is with a Cc306, stock waterpump, stock tb, stock heads. Car made 348rwhp and 344rwtq.
Old Aug 26, 2003 | 10:05 PM
atljar's Avatar
the 306 = 230/244 .510/.540 (with 1.5) on 112
the 847 = 234/242 .539/.558 (with 1.5) on 112
Old Aug 26, 2003 | 10:27 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
i am partial to cam motion. I have used them in several motors with good success. I also sell them
Old Aug 26, 2003 | 10:33 PM
Smokn '94 Z's Avatar
Unhappy
Dammmm!!!! You guys are really selling me on a GM 847... Maybe this winter.
Old Aug 27, 2003 | 12:03 AM
PhoenixCIS's Avatar
im going with the xe 230/236. i should have some numbers soon. i also have lt4 heads and intake fully ported and polished. ill post the numbers when i have them. thats with 1.6rr's.
Old Aug 27, 2003 | 12:17 AM
Dans91's Avatar
now my next question would be, if i have the lt4 heads do i have to change out my springs and stuff to handle the gm 847?? or would the stock lt4 springs handle it??
Thanx
Dan
Old Aug 27, 2003 | 12:33 AM
atljar's Avatar
Thanx
Dan
Those LT4 springs will have your valves toasted within 5 min of initial startup. They arent even close to cutting it.
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
pimpss96
Feb 12, 2015 01:28 PM
95chwagon
Jan 13, 2015 09:19 PM
