Ported intake???
Old Jun 1, 2009 | 01:02 PM
19~Camaro~90's Avatar
Ported intake???
Will a ported intake that will use a 58mm tb work with a stock tb or will it not run that well?
thanks
keivn
Old Jun 1, 2009 | 01:15 PM
Stl94LT1's Avatar
Yes it will work.
Old Jun 1, 2009 | 07:40 PM
Will it run as good as a stock intake?
thanks
kevin
Old Jun 2, 2009 | 08:56 AM
hairbear21's Avatar
It won't really make a difference. If you go back to the stock TB, the maximum air allowed is going to be governed by the TB, not the intake. The biggest difference is that they port the two openings to fit the larger TB. It won't have any effect going back to stock.
Old Jun 2, 2009 | 09:09 AM
bqman's Avatar
If you port the intake and use a stock TB, it'll be like you didn't port the intake at all. It'll still run like stock. Same with the exhaust. If you port the exhaust and leave the manifold, it'll run as if you never ported it. Although, good to still do in case you decide to do upgrades on your TB and exhaust headers.
Old Jun 2, 2009 | 02:29 PM
Ok cool i found a polished one and wanted it but didnt know.
thanks
kevin
Noenav
Mar 1, 2019 07:38 AM
LT14LIFE
Feb 9, 2015 09:35 PM
rje
Sep 9, 2002 12:35 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
