ported heads ?'s (A LOT of pics)
FINALLY getting around to putting my ported heads on my car! I just have a few question. First off, should I try to fix the little holes where he ported through the head at the rocker studs. Second, how does the ports look? I know it's hard to tell from pics but just an opinion. And, how are these flow #'s? The flow #'s (@28") are .....
Lift Intake Exhaust
100 68 53
200 127 105
300 182 132
400 228 157
500 261 178
550 272 185
600 272 190
These #'s are with 2.00, 1.60 ferrea valves.
Here are some pics,
In this pic you can see the holes
Here's one of the runners
Here are a couple of the intake
Lift Intake Exhaust
100 68 53
200 127 105
300 182 132
400 228 157
500 261 178
550 272 185
600 272 190
Here are some pics,
A guy here in Ga. His name is Steve Chapman. It cost me $825 for EVERYTHING. I got new valves, heads AND intake ported. I already have the 26918's (old batch) so I did not need springs. The only down side,assuming these work well, is it took him a LONG time. He was very helpful though. I have a friend who has a set he ported on his car and he runs 6.1's in the 8th with a 383 and XFI cam. He said (my friend) that mine look A LOT better than his.
Dont worry about the hole where the rocker stud is, just use sealant on the studs when you install em. He left a lot more valve guide boss than I have seen left on the ai and le heads i've installed. His chamber work is pretty conservative too, overall i'd say thats a fairly mild port job. Thats not to say its bad, theres more to heads than eyeballing photos and flow numbers. Stick em on and see if they're worth the cash.
LOL, I'm sorry......I'm NOT a professional photographer!
I resized them thinking they would be easier to see. I will take new ones and hopefully they will be easier to see.
oldschool
Feb 9, 2016 09:21 PM
Wilson
Jul 21, 2002 05:08 PM
