Port and Polish LT1 Heads
Old Feb 27, 2003 | 11:50 AM
Green G0blin's Avatar
i have a quick question..i was intrested in getting my stock LT1 heads port and polished.....my question is....what is a valve job? and is it necessary? i mean i want to keep the stock valves...so i do i need a valve job?
and if i port and polish the heads...the header gaskets should work? i mean the holes will match up and all right? i wont have to get new gaskets for the headers?
Old Feb 27, 2003 | 11:58 AM
PatriotTA's Avatar
A valve job is only necessary when you want to go with larger size valves, so NO you don't need a valve job. Yes, all the ports will line up on your heads and gaskets.
Old Feb 27, 2003 | 12:03 PM
thanks a bunch..saved myself the 100 bucks.
Old Feb 27, 2003 | 01:12 PM
BUBBA's Avatar
Just make sure your port job includes pocket work. I.e, smooth and radius under the valves. You might save some money without the polishing too. Really don't know how much gain there is to polishing. JMHO
Killer94z
Jan 13, 2015 12:06 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
Teal94V-6
Aug 31, 2002 09:21 PM
Skull Leader
Aug 10, 2002 11:01 AM
