Port-matching the intake manifold?
Old Jul 29, 2004 | 06:11 PM
speed_demon24's Avatar
After seeing how small the runners on the intake manifold are compared to the heads runners, is there any HP gain from port-matching the intake manifold? Also, are there any directions that I could follow to port my intake manifold?
Old Jul 29, 2004 | 06:36 PM
94z'sson's Avatar
Re: Port-matching the intake manifold?
of course it would help if you port match the intake just be careful not to scar up the inside and make sure that you keep the edges straight and try to keep the inside of the runners smooth
Old Jul 29, 2004 | 08:18 PM
Josh-'04 GTO's Avatar
The intake manifold runners should maintain a consistent amount of taper from top of the runner down the gasket opening.
Old Jul 29, 2004 | 08:28 PM
Revolutionary's Avatar
There is very little to be gained by port matching there. If you have some extra $$ to spend use it to port the heads.
Old Jul 30, 2004 | 09:05 AM
Dave C. '97 Z28's Avatar
I think what he is talking about is port matching the intake to the heads. Yes, if there is an overhang, if you clean it up then there is something to be gained there. You should always blend it into the head (or the intake, whichever way you have to go) at least a 1/2 inch.
Be careful blending too far in on the pushrod side of the intake port in the head. It's really thin there.. Of course, you shouldn't be near this area unless you just plain have the wrong intake manifold on the motor.
-Dave C. '97 Z28
PS: Oh yea, and please don't grind on the heads with them still on the engine. All that aluminum dust won't make your internals very happy.
Old Jul 30, 2004 | 09:38 AM
The heads are already fully ported, they match the gasket perfect, I'm talking about port-matching the intake manifold runners to the gasket so they line up to the head.
Old Jul 30, 2004 | 11:36 AM
mrz28 73/97's Avatar
Yes you should see a hp gain from port matching your intake, I'm in the process of doing it for a 383 motor I'm building.
Old Jul 30, 2004 | 11:48 AM
Any tips on how to do it? I just bought a die grinder, and don't want to mess up at all.
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
TitoPR221
May 26, 2015 12:20 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
