Popping exhuast please help!
Old Jul 12, 2003 | 09:22 AM
  #16
LilJayV10's Avatar
Originally posted by revtime
I have Jet Hot LTs and Glasspack header mufflers, you get a measly pop, I get a machine gun staccato KA-POW. Sounds like the D Day invasion.
Old Jul 12, 2003 | 12:08 PM
  #17
pasmado15's Avatar
pop corn sounds...
I too have pop corn effects and it reminds me of the older days when emission controls did not exist.
Pop Corn is fat free
Old Jul 12, 2003 | 07:12 PM
  #18
bpipe95's Avatar
i fixed mine today thanks guys it was all in the ignition
wires burnt
and riped apart by the belt and i put a new coil on it.
woohooo
godanm
this thing kicks ***
Old Jul 12, 2003 | 07:59 PM
  #19
mehoffz24's Avatar
AS FAR AS I KNOW, popping is from a leak in the exh system, when you downshift it runs the motor at a higher RPM and that means oxygen is being sucked into the pipes through the leak,therefore igniting the fuel mixture in the pipes. i know it may sound weird that o2 can be getting sucked in when gasses are comming out with pressure but it makes sence to me because i was using a band clamp what was leaking slightly once i got that part welded , no more prob
Old Jul 13, 2003 | 04:38 PM
  #20
CamaroGuy22's Avatar
I have my cat back and y pipe welded on, and it still pops...
Old Jul 13, 2003 | 05:07 PM
  #21
TheV6Bird's Avatar
Would a true dual exhaust system get rid of the popping?
It would obviously be more expensive though...but it would sound soooooooooooooo much cooler!
Nayr
Mar 3, 2023 08:34 PM
Aaront810
Aug 29, 2020 09:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Toxintwins
Sep 11, 2015 11:13 AM
