Popping / Backfire from exhaust
Old May 24, 2004 | 01:04 PM
Red95M6Z28's Avatar
Ever since I put the Magnaflow cat back on I get a popping sound from the exhaust inbetween shifts. Its not a good pop like borla I know pops like mad. This sounds like a misfire out the tailpipes. I have searched through the site and not found much of an answer. Any help would be great.
Old May 24, 2004 | 02:19 PM
sabre81's Avatar
maybe you need a tuneup? your stock mufflers could have been masking the pops before.
Old May 24, 2004 | 02:23 PM
Red95M6Z28's Avatar
I forgot to mention I have a brand new water pump, GM opti, GM wires & plugs! I keep meaning to do the fuel filter. But I dont think thats causing a backfire. What else?
Old May 24, 2004 | 02:26 PM
sabre81's Avatar
Check egr system, one of my vaccuum lines came off and caused popping. Also check the evap lines evap lines . I broke one of these and did a half *** job on the fix. About 2 weeks later the vaccuum line broke again causing louder popping
Old May 24, 2004 | 02:50 PM
TrouserSnake's Avatar
go over you spark plugs where they snap onto the plug and opti..
Old May 24, 2004 | 02:56 PM
aintno6's Avatar
your car might just be running rich.
People have had the same problem, and once they had the engine leaned out a little bit. It got rid of most of the popping and backfiring.
Im not sure if this is the same issue. But LT1's do run rich from the factory.
Z28Freak86
Apr 30, 2024 05:37 PM
Chet1185
May 10, 2015 09:24 AM
SigSauer40
Exhaust System
Apr 29, 2015 09:02 AM
Drtryder
Apr 22, 2015 04:17 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
