disable egr and smog pump?
Old May 24, 2004 | 10:03 AM
toneloc12345's Avatar
i have a 1996 Formula and i had MadZ28 tune it. I had him disable the egr and smog pump, my car seems a little slower now. Should i send it back sometime to turn those back on?
TONY
Old May 24, 2004 | 10:13 AM
cmking26's Avatar
Make sure when you removed the egr that you dont have a vacuum leak. It shouldn't run any slower. I would check for leaks first.
Old May 24, 2004 | 10:46 AM
i didn't remove the EGR valve, before i got it tuned i had a SES light for the egr vavle.
TONY
Old May 24, 2004 | 02:58 PM
Maybe you have a real problem with the valve, itself. You might want to be sure it is not stuck open or something.
HectorM52
Jul 30, 2017 11:46 AM
edman
Mar 13, 2015 09:39 PM
alphaauto
Jan 23, 2015 07:42 AM
cmdeshon
Dec 27, 2014 10:06 AM
Timberwolf
Aug 9, 2002 11:24 AM
