Pop-Up Headlight Question
Old Jul 3, 2003 | 03:40 AM
Laymaster's Avatar
Ok in the past month twice my passenger headlight has failed to pop up. It won't pop up unless I manually set it up, then it will go down and come up no problem (for a week or so). Is the motor on its way out? Thanks in advance....
Old Jul 3, 2003 | 08:00 AM
Fatdog's Avatar
Cool
Chances are it's just the nylon gear inside the motor.Go to Brents94 web page,as he has an easy fix,and offers a better replacement(brass)gear for sale.Hope this helps.
Old Jul 3, 2003 | 08:14 AM
Laymaster's Avatar
no it's not the nylon gear. The lights aren't grinding or anything (and i did the 180 swap about a year ago)....
Old Jul 4, 2003 | 12:07 AM
fbird95's Avatar
Unplug the good side, have a second person turn on the lights and see if the motor attempts to turn anything, next time it starts eacting up. This will be a good indication on wheather or not the motor is dying, or even getting power. You can also take out the fuse from the good light to keep it from making noise during the test.
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
