Pop starting an M6...
Old Jun 21, 2004 | 11:05 AM
Bow94z's Avatar
how bad is it to pop start a car ( push the car then relase the clutch in 1st gear to get it started) does this put wear on the clutch? or any other parts? just curious, cause i have done this several times and it doesnt seem to affect anything
Old Jun 21, 2004 | 11:28 AM
simple's Avatar
you'll be fine
Old Jun 21, 2004 | 11:41 AM
Bow94z's Avatar
yea i kno ill be fine if the car is still running in perfect order....just wondering what kind of wear this puts on the car.....
thanks
Old Jun 21, 2004 | 12:11 PM
truedualws6's Avatar
Use 2nd or 3rd gear. Makes it a lot easier.
Old Jun 21, 2004 | 12:32 PM
Bow94z's Avatar
really, 2nd or 3rd gets it started easier? hmmm even from a push from friends or something.
cool learn new info everyday
Old Jun 21, 2004 | 02:07 PM
Rocks94z28's Avatar
high gears work better for pop starting i thought, in my jeep i used 4th
Old Jun 21, 2004 | 02:10 PM
Red96Lt1's Avatar
I always use2nd when I push start mine.
Old Jun 21, 2004 | 03:47 PM
Brent94Z's Avatar
Super Moderator
I'd recommend just getting a new battery
Old Jun 21, 2004 | 04:10 PM
simple's Avatar
or starter
Old Jun 21, 2004 | 04:44 PM
Bow94z's Avatar
well, its cause i was tuning my radio, and it died quickly. noone was around to get me jumped so i just pop started it in the driveway...that was my situation, just wondering what type of wear it could cause
Old Jun 21, 2004 | 06:15 PM
x7x7's Avatar
I use 4th, 1st would be pretty harsh.
Old Jun 21, 2004 | 07:19 PM
Zepher's Avatar
If your battery is drained too much, you won't be able to start your car no matter how fast you push it. You don't have power to run the pump, injectors, or the PCM.
Old Jun 21, 2004 | 09:41 PM
MY91Y84's Avatar
yea but after he starts it the Alt will take over..and since the starting circuit isnt working, all remaining power will go to the injectors/plugs after the motor has started spinning
ChrisFrez
Feb 15, 2015 08:12 AM
Amshnock
14
Jan 18, 2015 11:47 AM
hotrod 5210
Dec 22, 2014 07:28 AM
Achilles97
Sep 12, 2002 11:57 AM
FASTFATBOY
Jun 20, 2002 11:27 AM
