poor idle
Old May 30, 2005 | 06:32 PM
gillt1's Avatar
Unhappy poor idle
Just finished rebuild ,fired up climbs to 3000rpm then slowly dies ,will keep running if I keep pumping throttle , seems like low fuel pressure or too much fuel ,any advice? Thanks Gil
Old May 30, 2005 | 11:15 PM
ayalam's Avatar
Re: poor idle
Reset the iac. go to shbox.com for directions on how to do it I would also check for compression, clean the throttle body, and clean the maf sensor with electric parts cleaner.
Old May 31, 2005 | 10:19 AM
1quickTA's Avatar
Re: poor idle
Check your vacuum lines. I put in headers and tried to fire it up without blocking the EGR holes in the back of the intake and had a similar problems. I also had a cracked vacuum hose later and had a bad idle.
PopoFormula
Oct 12, 2015 04:19 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Double aught
Oct 2, 2015 11:29 PM
tommalcolm
Sep 11, 2015 03:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
