Poly Engine Mount Orientation?
Old Nov 15, 2004 | 08:51 PM
y5e06's Avatar
Which way is correct?
http://www.vilipend.com/~frrax/Assembly-Part-II
It looks like position #1 should be correct. However, the instructions are very poor for the LT1 mount (indicating to place the wide tab on the 'wide spaced hole' side).
other interesting photos: http://www.vilipend.com/~frrax/y5e06
Old Nov 15, 2004 | 09:00 PM
Spinner's Avatar
Re: Poly Engine Mount Orientation?
#1, the tab can cause clearance problems the other way around, though you could make it work either way.
Old Nov 16, 2004 | 11:33 AM
TobyZ28's Avatar
Hey just curious, how do you take out the old mounts and put in the new ones? (which bolts?)
Old Nov 16, 2004 | 11:57 AM
Red96Lt1's Avatar
When I did it with the engine in the car, I had to support the motor with a hoist (I'm sure you could use a floor jack) and pull the enitre clamshell mount off. The clamshell assembly is held together with some huge rivits. You have to take a grinder and grind them out to seperate the clamshell. I tried using a drill with an abrasive attachment and ended up purchasing a grinder. After that you just use the supplied hardware and put the new ones back in. BTW, it was a biotch for me to line everything back up. Poly doesn't give near as much as the rubber.
Jason Short
Jan 19, 2015 06:34 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
rpm4lalo
Aug 3, 2002 02:35 PM
