PlugWires
Old Aug 7, 2010 | 10:48 PM
lt1le2's Avatar
PlugWires
Does anyone know if there is a brand of plugwires that are longer then stock and put together already? I need these for a 95 camaro
Old Aug 8, 2010 | 02:06 AM
purple 95 z28's Avatar
Not that I know of. But you could always buy 2 sets and use the longer ones from each set.....
Old Aug 8, 2010 | 09:00 AM
Perhaps if you explained why you need longer wires, someone here could come up with a creative solution, or explain what they have done in a similar situation......
Old Aug 8, 2010 | 02:10 PM
lt1le2's Avatar
I have mid headers on my car and I have chrome valve covers I have the side plugwire mounts from thunder racing my engine bay is cluttered I want to try stock location with fireproof boots I just need some longer wires that are already put together.
Sent from my ADR6300 using Tapatalk
Old Aug 8, 2010 | 11:43 PM
lt1le2's Avatar
Bump
Old Aug 11, 2010 | 11:12 PM
lt1le2's Avatar
Bump
Old Sep 1, 2010 | 09:13 PM
lt1le2's Avatar
plugs
bump still looking for ideas
Old Sep 2, 2010 | 11:26 AM
Z28SORR's Avatar
The most likely reason your not getting any responses is because NO ONE is going to have pre-made wires for a custom job!
And, putting boots and ends on spark plug wires is one of the easiest things you can do. So if you can't handle doing this, you probably shouldn't be mucking with the car in the first place!!!
Personally I like, and have used for years and years MSD wires. (the universal set)
Old Sep 2, 2010 | 12:19 PM
Kevin Blown 95 TA's Avatar
You can get a good set of universal wires and a good crimper for roughly what two sets of good wires cost, so that is what you should do. Don't get the $15 crimpers, and shop around for the better ones because I think they are all made in the same place and can be $68 but I have seen them for half that occasionally. If there's any question, just get the Accell ones and use those.
Old Sep 3, 2010 | 12:14 AM
19camaro71's Avatar
get the thunder racing over the valve cover kit...
wires
Old Sep 3, 2010 | 07:47 AM
bw_hunter's Avatar
Look at the Magnecor KV85 wires. They sell both stock length as well as longer ones for header applications. Both run in the stock location..
will.b.brown
Parts Wanted
Sep 24, 2012 02:37 PM
lt1le2
Parts Wanted
Apr 21, 2009 07:31 AM
lt1le2
Jan 20, 2009 05:54 PM
