Plugs glowing blue?????
Old Jul 7, 2003 | 09:47 PM
1994Hawk's Avatar
Ok well my i looked under my hood at night, and sure enough most of the plugs, and coil wire, seem to be glowing, or flickering blue, i just replaced all plugs and wires the other day, but didnt use any di electric grease, is that y its doing this?
Old Jul 7, 2003 | 10:03 PM
96z's Avatar
96z
For some reason they are arcing. The grease wont necessarily prevent them from doing this but will help against it. Did you make the wires your self? Are you sure they are pushed down all the way?
Old Jul 7, 2003 | 10:06 PM
1994Hawk's Avatar
Yea, all the wires are on tight
Old Jul 7, 2003 | 10:11 PM
96z's Avatar
96z
Try some grease than and see if that helps any....
Old Jul 7, 2003 | 10:17 PM
A blue glow (corona) is not an arc and is considered normal at the plug. It will not harm anything or hurt performance.
Dielectric grease should still be used when you work with your wires.
Old Jul 7, 2003 | 10:18 PM
1994Hawk's Avatar
ok, well then can you help me solve y its missing now??..
Old Jul 7, 2003 | 10:21 PM
You did not say anything about missing in your original post. Surely, arcing can cause a miss and so can lots of things. Comb over all ignition connections. Could be the opti or even something to do with valves. Maybe some more input on your miss will help.
Old Jul 7, 2003 | 10:23 PM
1994Hawk's Avatar
ok, my car was missing the other day, i opened the hood and saw plugs flickering, thinking that was bad, i changed all the plugs and wires. Car ran great last night and early today. May be a coincidence, but i was out driving in the rain, and all of a sudden while deccelerating, it began to have a rough idle, the car feels like its on 7 cylinders and is getting bad gas mileage
Old Jul 7, 2003 | 10:25 PM
96z's Avatar
96z
If its missing than one of your wires is crossed up or arcing
Make sure they arent getting burned too, thats often a culprit also.
Critter
Jul 7, 2015 08:33 PM
PROJECT X
Apr 17, 2015 12:13 AM
captcorvette
Mar 7, 2015 12:37 PM
jayvar
Feb 2, 2015 10:00 PM
99TransAmWS6
Jul 26, 2002 03:18 PM
