plugs
Old May 28, 2009 | 11:10 AM
steven92f's Avatar
plugs
i have a 96 z28 with a lt1 5.7. when changing spark plugs. do you have to remove anything from the engine when you are replacing the spark plugs or can you do it without removing anything
Old May 28, 2009 | 11:34 AM
96_Camaro_B4C's Avatar
It's easier to just pull the engine.
I know I have to pull the starter (or at least unbolt it and tilt it out of the way) to reach #8. Also, I think having the alternator and the rear brackets (the black arms) out of the way helps. Mine was already removed because I did my plugs when I had the intake manifold off last year to fix the rear leak...
I think the driver's side is alright without really removing anything, but IIRC I also got #7 from underneath.
I'm glad I've only had to do that job once, though now I'm in the middle of changing the wires, which is about as bad... Good luck!
Old Jun 12, 2010 | 04:16 PM
afwmcw's Avatar
Hi, I just wonder how you made out changing your spark plugs on your z28? Thank you,Mark
Old Jun 12, 2010 | 08:00 PM
The original poster, "steven92f" has not been active on the site since 3/13/10. You might want to send him an e-mail.
Or search for related threads on changing plugs - how to. There are many threads, and one in the past couple weeks.
KYWes
Jun 14, 2022 06:52 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
350350
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
Xiantyl
Jul 21, 2015 05:42 AM
