plugs
Old Apr 1, 2007 | 07:31 AM
snareman's Avatar
Smile plugs
right now on my 93 z I have msd cap,rotor,plug wires and ngk platinum plugs.would I pick up any performance switching my plugs to a different one. they only have about 3000 miles on them.let me know what you think and what you run. thanks,snareman
Old Apr 1, 2007 | 08:03 AM
CrazyLT1's Avatar
You should tell us more about your car so we can give you better advice. If the car is relatively stock - you will not gain any performance by switching plugs. Plus those plugs you are using are good plugs anyways..
If you had very high compression OR were using a forced induction set-up - then you would want to switch to some colder burning plugs. But if thats not the case - then you should be fine
Old Apr 1, 2007 | 08:14 AM
snareman's Avatar
plugs
93z,lt1 700 r4, midwest 2800 stall,nittos.no cat 1 le intake bellows,tpi airfoil,lingenfelter cai ,hooker aerochamber with ss tips.msd cap,rotor,wires.bmr str and lcas.rebuilt performance trannywith transgo kit and ls1 tranny mount,b and m 24,000 cooler.just a hair over stock(so far).
Old Apr 1, 2007 | 08:24 AM
CrazyLT1's Avatar
Well until you go into the motor - or add nitrous or forced induction - then those plugs will be fine. They are darn good plugs anyways!
If you end up doing any of those above stated things - then you will want to switch to a little colder plug to prevent detonation. Such as:
NGK tr6's
Autolite 104's
etc.
but for now, you should be great with those
By the way, you are off to a great start with the mods you have done thus far
Old Apr 1, 2007 | 12:40 PM
2000GTP's Avatar
Nothing wrong with NGK.. they are a very good plug.
KYWes
Jun 14, 2022 06:52 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
350350
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
Xiantyl
Jul 21, 2015 05:42 AM
