pluging the timing chain hole
Old Jul 7, 2004 | 09:12 PM
huskersZ's Avatar
Hey Guys. I need some quick tech info. I am doing away with the mechanical water pump for a electric one and a double roller timining chain set up. What size freeze plug is needed to plug the hole in the timing chain cover where the wp shaft came out of. If not a freeze plug, what are you guys using to plug the hole. Thanks for the info in advance
Old Jul 7, 2004 | 09:40 PM
magnumv8's Avatar
yep, use a freeze plug. I cant remember the size, but I am thinking 1 1/8 inch.
Old Jul 7, 2004 | 09:49 PM
Spinner's Avatar
Electric pump comes with the freeze plug
Old Jul 7, 2004 | 10:07 PM
ibanez6rg's Avatar
For the waterpump housing it does. Not for the timing cover or block.
Old Jul 7, 2004 | 10:10 PM
J's 82's Avatar
I used some 5 min weld epoxy (quicksteel?).. has held up for 17k miles with no leak whatsoever.. took a good look at it when I did my head and cam swap last weekend and there has been no degradation of the material.
Old Jul 7, 2004 | 10:23 PM
Spinner's Avatar
BRain fart. Yeah. I dont know what the exact size is, I just brought my cover to the hardware store and asked for one that fit. The guy took it behind the counter and I was out the door in 2 minutes
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
