pluging off some water lines on heads???
Old Feb 6, 2006 | 03:33 PM
chrisbz28ss's Avatar
I put some trick flow heads on my 95z28 ,an wanted to know if i could plug off some of the water lines ,on the back of the heads . or do i have to keep that stock set up?
Old Feb 6, 2006 | 03:52 PM
Re: pluging off some water lines on heads???
From the "Rebuilding the LT1" article....
EXTERNAL COOLANT LINES
There is an extra hole that goes into the water jacket on both ends of the heads. These should be plugged when they’re in the front, but left open when they’re on the back. There’ s an external coolant transfer line that connects the holes on the back side to a reservoir that vents the air and steam vapors that would be trapped in the head and cause hot spots.
Old Feb 6, 2006 | 09:41 PM
thanks , i have lost one of the bolts that goes in the head (the one with the holes in it) anyone know where to get one?
Old Feb 6, 2006 | 09:43 PM
Birdman7389's Avatar
You can get the whole line with bolts from GM for a pretty reasonable price, I think it was around $20 from Jason Cromer
Old Feb 6, 2006 | 11:31 PM
thanks
HectorM52
Jul 30, 2017 11:46 AM
MattFick
Feb 15, 2015 10:16 PM
Jazsun
Dec 29, 2014 12:14 PM
