Plugging water pump hole on timing cover?
Old 07-18-2003, 10:21 AM
chucks97ss's Avatar
Switched to a double roller and csi electric water pump... What's the most common method of plugging the hole left in the timing cover?
Chuck
chucks97ss is offline
Old 07-18-2003, 10:37 AM
M93Z's Avatar
I used a 1 7/32" soft plug with anaerobic sealer. I polished the outside of the plug with emery cloth as it was slightly oversize.
M93Z is offline
Old 07-18-2003, 11:01 AM
97FormulaWS-6's Avatar
I used a freeze plug I got from the local parts store.
97FormulaWS-6 is offline
Old 07-18-2003, 12:15 PM
kirschman's Avatar
Freeze plug, not the normal one though. Get the kind that look like the lense on a pair of glasses, (concave?) Search my user name (i cant member the size) but I found one that fits perfect. You need to lay it on the ground and just slightly flatten it with a hammer, put some RTV around the hole and tap it in. Mine fit REAL snug, not a leak in sight yet. Just take the t/c to the parts house with ya and ask em to let u go through the freeze out plugs.
kirschman is offline
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
Jazsun
12-29-2014 12:14 PM
Queens94z28
12-20-2014 09:11 PM
Quick Reply: Plugging water pump hole on timing cover?
