Plug wire heat resistance question? OVC kit best?
Old Feb 22, 2004 | 02:25 PM
Steve0's Avatar
I have a set of Mac headers on the way, without a ceramic finish on them and when I do the install, I will also be changing the plugs and wires.
I dont want to burn up any plug wires so my question has to do with what kind should i get? I've been looking at the Taylor Spiro Pros and the Accel 9000's.
The Accels are supposed to be extremely heat reistant, I believe up to like 1000 degrees, and the Taylors up to 600 degrees or so. The difference is the Taylors are $25 cheaper, and I know its shallow, but come in red!
I've also seen the over the valve cover loom kit available at thunderracing for $100. If its better to go that route, and never risk burning a wire, I may just spring the extra 50 bucks. Anyone run that kit?
Thanks!
Old Feb 22, 2004 | 02:34 PM
scoobysnax83's Avatar
I just bought em, we'll see
Old Feb 22, 2004 | 02:48 PM
Zack's Avatar
i ordered the OTVC set up for my MAC headers. It was kind of a PITA taking the old wires out of the stock location, AND I was being aggresive too! So i only figured it would be a bigger pain routing them through the stock looms.
Old Feb 22, 2004 | 02:57 PM
It is!
Old Feb 22, 2004 | 03:10 PM
RamAir95TA's Avatar
I have the OTVC kit from Thunder Racing with Taylor wires with MAC headers. Works wonderfully.
http://www.ramair95ta.com/tech/wirelooms1.jpg
http://www.ramair95ta.com/tech/wirelooms2.jpg
http://www.ramair95ta.com/tech/wirelooms3.jpg
Old Feb 22, 2004 | 03:12 PM
yikes are those routed correctly?
Old Feb 22, 2004 | 03:16 PM
RamAir95TA's Avatar
What do you mean?
Old Feb 22, 2004 | 03:18 PM
In the picture, it kind of looks like #2 is all over that header. Could be the angel...
Edit: It seems to me that if you were to not route #2 through that second loom and then made the wire shorter that it would look better.
I am in no way saying that it looks bad, I'm just throwin ideas out.
Old Feb 22, 2004 | 06:20 PM
Steve0's Avatar
Those of you with the OTVC kit, how hard was it to crimp the wires and install everything? I'm guessing its about a 2 hour project?
Old Feb 22, 2004 | 07:18 PM
JoeliusZ28's Avatar
Thumbs up
make sure you take pics of the header and wire install and let us know how it goes, im looking to do the same setup on my car [If/when I get the money]
Old Feb 22, 2004 | 07:21 PM
Zack's Avatar
when I opened up my wires, I was scared ****less of how to do that. I still havent, and fear the day it comes. I dont even know how to use the tool to do all that stuff
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
