Please Read Need Help
Old May 16, 2005 | 02:00 PM
flounder564's Avatar
I Got A 94 Z28 And I Need To Wash My Engine And I Wanted To Find Out The Wright Way To Do It Before I Just Started Spraying Water Every Where
Old May 16, 2005 | 02:09 PM
breakmyfootoff's Avatar
Re: Please Read Need Help
Definately dont spray water everywhere, You'll get lots of different opinions on this, some people use pressure washers on thier engines with no troubl, I on the other had went through 3 optis in about 6 months 2 of them were when I had to drive the car on the highway in the rain and one was from washing the car at the car wash with the pressure washer. Mine is a 94 and has the non-vented opti, some 94 cars had the vented opti, you need to find out which one yours is becuase the vented ones seem to resist water a little better. After the trouble I had with optis I do not spray water into the engine bay anymore, I just wipe the engine down with towels that have cleaner or water on them and then dru it with clean towels, it's more of a pain in the *** but so is replacing an opti, and rags are cheaper
Old May 16, 2005 | 02:41 PM
69gto96z's Avatar
If you are going to spray water in the engine bay, find a way to cover up the alternator, computer, and the opti-spark. Anything else that is power related should be covered up. And take the battery out when you are doing it. Hope this helps...
Old May 17, 2005 | 09:37 AM
i wish i would have read your thread in time because i didnt cover anything up and i left the battery in. so shortly after driving my car i stopped at a friends house and as i was leaving i crank up my car and started to pull off and the car just died my guess is i did something to the battery because i lost power to everything even after jumping it off for ten minutes the lights wouldnt come on, ANY IDEAS
DirtyDaveW
Dec 1, 2016 05:37 PM
ad356
Apr 22, 2015 08:35 PM
aj2494
Mar 12, 2015 10:17 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
