Please read this before you choose a cam!
Old Apr 11, 2005 | 10:30 PM
  #61
stereomandan's Avatar
Re: Please read this before you choose a cam!
Originally Posted by Shon Herron
My experience was with the A4 and TH350. and Valve float was not an issue, CC987 springs with the Ti stuff....Comp R lifters, Pro Mags, etc....it was the set up. I have seen many HOT cam graphs and would agree that power might be had up there but not in my case....
Yeah, that's probably it. That combo is fairly different from the M6. You knew your system the best, so I really shouldn't question it.
All in all though, going by the dyno plot, and the tranny gearing, you can choose your optimal shift points assuming that your tranny is working the way it's supposed to.
Dan
Old Apr 12, 2005 | 07:24 AM
  #62
Shon Herron's Avatar
Dan
I do agree that the Dyno plot should tell a person where to place the shift points. and it does matter the gearing of both the rear and trans.
Sure wish I had that A3/355 combo back...went 11.96 on motor with the HOT cam and there was more in it....oh well....starting over is fun too!!
Old Apr 20, 2005 | 07:03 PM
  #63
RicocheT's Avatar
trying to keep this thread alive to get more opinions/facts. Doing some research on what cam I want to install at some point in my 94 M6 . I generally look at the lift numbers more than duration.
Old Apr 20, 2005 | 07:21 PM
  #64
Mindgame's Avatar
I would worry more about the duration than the lift. You can realize HP gains from high acceleration cams but you have to have the right valvetrain components. Otherwise you're gonna be changing out lower quality (street) springs on a regular basis. In other words... you'll need a better (more expensive) spring.
As for specs.... give Cam Motion a call. They will be more than happy to work with you on a custom grind that fits your needs.
-Mindgame
Old Apr 20, 2005 | 09:46 PM
  #65
RicocheT's Avatar
Thanks for the info mindgame, Im far from doing anything to my z. Just trying to do some homework. Was leaning towards a 224/230, or 230/236 but that maybe a bit on the big side. I considered the 230/236 b/c I see some people say its not bad with a M6. anyhow, I have a few other projects to finish before I can start buying things, so I have plenty of time to figure something out.
Old Apr 20, 2005 | 10:58 PM
  #66
vette40th's Avatar
Originally Posted by madwolf
I've seen TOO MANY instances were people go with a big cam (847, 306, etc) and they rev or plan to rev the cam to about 6100-6200. DO NOT get a cam that big if you will rev it to only 6100-6200 or even 6300. You will get CRAPPY times if you do. These cams like 6700-6800 shifts!
If you do a 847, 306, 233/239 or even 230/236 and shift at 61-6200ish, you will be in the low 13s! You'll be lucky for a high 12.
There are plenty of cams out there which can take advantage of your targeted range much better and will yield better times than a bigger cam in the same range. Please consider this.
Yes, I've had at least 2 people with a 306 requesting a 6200 rev limiter and a number of other people who shift at 6100-6200ish and that's on the stock tach, which is about 5900 real RPM.
I run 11's and I shift at 6200 rpm with my 230/236 cam.
Old Aug 12, 2005 | 09:01 AM
  #67
Bersaglieri's Avatar
Very good thread on cams!
I was wondering if anyone had opinions on the GM 846 camshaft for a daily driver mods in sig. Its a Crane Grind 222/230 .509/.528 with 1.5 rockers. The ones I have seen are ground on a 112 LSA. How high to these rev and what kind of power or times are folks seeing?
How would it compare to the Hotcam? The valvetrain I have now would support just dropping in the $175 Hotcam, but something tells me I might want a little more.
Keeping this thread alive!
-Dustin-
Old Aug 12, 2005 | 09:22 AM
  #68
jsetzer's Avatar
306 stock heads m6 4.10 guy here. I am happy with the cam. No issues with daily driving. So far I have been shifting at 6500, but it still feels like a beast, even if I hit the rev limiter.... so I was thinking of going to 6700-6800. That still got me 109mph trap with some minor issues. I expect a 110 trap with good weather, and maybe a bit higher shift. One problem thoug is shifting at 6500 had me crossing the trap at a relatively low rpm, even with 4.10s.
Old Aug 12, 2005 | 09:50 AM
  #69
Gripenfelter's Avatar
Just to put some myths to rest...
I have a '93 LT1 with an LE2 cam which is similar to the GM847. I rev my 383 to 7200 rpm.
Old Aug 12, 2005 | 10:28 AM
  #70
pillagenburn's Avatar
I was looking at the Crane Cams 222/230 .509 / .529 112 LSA
would it be ok for a 6200 rpm redline? I just don't want to rev my stocker shortblock very high.... if i can get away with 6000 rpm redline i'll do it....
the cam seems to have more lift than the cc305 on the exhaust side but im not sure...
opinions? would use it with crane 1.6 rockers and comp 941 valve springs
Old Aug 12, 2005 | 10:38 AM
  #71
Thats the same cam I mentioned above, its also called the GM 846. It does have more lift on the exhaust and a bit more intake duration than the CC305 and many like that its billet instead of cast and some like the lobe design better. A fellow with ported heads is putting down 370's with it. He's using Crane 99893 springs. Many use the Crane 10308's too.
CC305 220/230 .510/.510
GM 846 222/230 .509/.528
-Dustin-
Old Aug 12, 2005 | 11:29 AM
  #72
yes, but would it be effective to a 6000 rpm redline? or 6200 rpm redline even? the GM846 that is
Old Aug 12, 2005 | 11:51 AM
  #73
Thats the same question I am asking. I bet its closer to 6200-6400 range. Lets hear what the more experience guys have to say...
-Dustin-
Old Nov 27, 2006 | 01:13 PM
  #74
JoeliusZ28's Avatar
With a 224/230, you should be shifting at around 6400-6500 for best track times. If it's hitting a wall after 6000, you have problems. (springs, ignition, etc)
Ion... kinda bringing this one back up from the dead, but do you think the 224/230 is a good choice even if you plan to shift at 6200? (stock heads). im not necessarily concerned about squeezing the best time out of my car, but id like the power there.
Old Nov 27, 2006 | 01:28 PM
  #75
Javier97Z28's Avatar
Moderator
I had my A4 shifting at 6250 with the 224/230, I trapped 112.81 with stock heads. So yah, it'll work well.
I really don't think that cam would make power at 6400 anyways..
