Please read this before you choose a cam!
Old Apr 9, 2005 | 10:07 PM
  #16
1 Nasty Bird's Avatar
Re: Please read this before you choose a cam!
So just how fast can you spin a HEALTHY, STOCK, LT1 shortblock. Just the shortblock, not talking about the valvtrain etc. Just the shortblock.
Old Apr 9, 2005 | 10:26 PM
  #17
Alvin@pcmforless.com's Avatar
I agree with what Ion is saying.. Sometimes people just thing bigger is better when something reasonable will get the car there and at the same time let it drive, idle, pass emmissions, and not REQUIRE a healthy stall to run decent.
I used to turn my stock shortblock to 6300-6600 with a nice set of heads Just to keep it under the curve
Old Apr 9, 2005 | 10:30 PM
  #18
cat1055man's Avatar
Amen Madwolf...I agree that a smaller cam will out perform a big one and provide better driveability overall if you are only going to rev 6200. My hot cam pulls great and is still going when I shift at 6200. I experiance some cam surge in first and second holding the throttle stead under 1800. Under a load accelerating its steady from 1200 up. The larger cams must really buck and surge at low rpm light throttle conditions.
Old Apr 10, 2005 | 12:28 AM
  #19
Capt'n Two Rotors's Avatar
mine turns higher than the pcm will go when I'm at the track and with the 847 it's still pulling.
Old Apr 10, 2005 | 12:31 AM
  #20
Mine doesn't surge bad at all(gm847), I notice it but passagers don't. When I first got my tune it did quite bad but 2 nights at the track and some driving around town and the surge isn't enough for datamaster to even pickup anymore. If you are getting surge with a hotcam I would think your tune belongs in a dumpster somewhere.
Old Apr 10, 2005 | 03:00 AM
  #21
Daniel6718's Avatar
so if you have an 847 with mildly ported stock heads...with a good fresh stock bottomend...and you want to rev to say...6800 to shift and have the rev limitor at 7000 what kinda valve springs do yall use??? im planin on this soon
Old Apr 10, 2005 | 03:41 AM
  #22
madwolf's Avatar
Originally Posted by Mindgame
I don't think you realize the can of worms you're opening here.
The "rev limit" is not solely dependent on the camshaft duration. What about the cylinder head port? What about the valvetrain??
If I were to take two identical LT1's, one with stock heads, the other with a set of AFR 200's (for comparisons sake), both with identical camshafts and valvetrain components. Think they're gonna shut off at the same rpm?
There are a lot of factors that will determine "where" peak power occurs, the camshaft is only 1 variable in that equation.
BTW, I like the new doo.
-Mindgame
I knew I was going to get some old timer criticism for this post.
Just to clarify, this was meant for people you see posting here every day. Stock heads, motor, etc and they want to get a 306, 847, or whichever idles "meaner".
I did a program for a 24x/25x hydraulic roller on stock heads not too long ago. Why would someone want a cam like that on stock heads, is beyond me.
Old Apr 10, 2005 | 08:55 AM
  #23
BlackbirdWS6's Avatar
I have my rev limiter at 6500 on the stock tach, but I use a shiftlight set to go off at 6300. I was getting killed by the stock tach when I was supposedly shifting at 6500, but it was prob more like 6400 or even lower. Once that problem was solved I was trapping almost 4-5 mph more.
Old Apr 10, 2005 | 09:39 AM
  #24
Heatmaker's Avatar
Advanced Member
"And the bearings spun all around all around....and the bearings spun all around....and the guy with the Camaro went WTF! WTF! WTF!...all the way to the deeeaaaaleeeeer.."
Old Apr 10, 2005 | 10:48 AM
  #25
txbitt's Avatar
Hey Ion, I set my rev limiter low also, but just because I think I'm floating a valve or valves at about 6K . As soon as I get new springs I will send PCM back to you to change. Can I just delete stock rev. limiter and use the one on my H-I6 ?
Old Apr 10, 2005 | 10:55 AM
  #26
madwolf's Avatar
Yep. Using the ignition rev limiter is a better idea if you have one.
Old Apr 10, 2005 | 11:02 AM
  #27
OldSStroker's Avatar
I resemble that remark.
Why a reputable engine designer/builder would sell a cam like that for a basically stock application is beyond me.
My $.02
Old Apr 10, 2005 | 11:10 AM
  #28
Jameslt1TA's Avatar
Hey Ion did you read my post on page one of this thread?
Also i think that the 230/236 is still kinda big even on ported heads...even though i sometimes wish that i had gone with the cc306.
Old Apr 10, 2005 | 11:29 AM
  #29
faded93bird's Avatar
Rev-Limiter ?? What is this thing called rev-limiter you speak of
Faded
Baah! You Dont need one of those spin it to the moon
Old Apr 10, 2005 | 11:30 AM
  #30
speed_demon24's Avatar
And don't think small cam's can't make any power. I still trapped 115.1 with my tiney 210/224 cam with a few bugs to work out. Thats full weight and no skinny's bogging out of the whole. I have no doubt I could hit 117mph with this cam at a 3600lb race weight.
