Please read this before you choose a cam!
Old Apr 10, 2005 | 01:36 PM
  #31
Capt'n Two Rotors's Avatar
Re: Please read this before you choose a cam!
Originally Posted by madwolf
Why would someone want a cam like that on stock heads, is beyond me.
Maybe they are planning to heads down the road,why buy two cams??
Old Apr 10, 2005 | 01:48 PM
  #32
Heatmaker's Avatar
Advanced Member
It's very simple...
no one wants to put a big came on stock heads... the thing is... most people don't have $2XXX.00 to spend on a set of good heads... and at $2XX.00 a cam is much cheaper and proven performance. THe heads can always come later.
Old Apr 10, 2005 | 02:11 PM
  #33
jchevy's Avatar
The problem is people are more worried about the lopey idle and peak HP than they are about a broad powerband and good drivability.
Old Apr 10, 2005 | 02:29 PM
  #34
vette40th's Avatar
My 396 Hot Cammed motor trapped 118 mph. Now I am going to the XE 230/236 cam, and after the dyno I will determine my shift point, but if you have any suggestions, please let me know, as the dyno wont be for a couple weeks.
ps, my motor is built to rev, and heads exhaust etc to match.
Old Apr 10, 2005 | 03:21 PM
  #35
JBird33's Avatar
Ok then, I have a question for all you cam gurus. I plan on basically making my car a street car, go to the strip every now and then. It is my only car, a daily driver, and I'm not planning on doing anything too nutty. I'm thinking bolt-ons and a cam. What would be an ideal cam for me? I don't want to rev the motor too much, maybe slightly higher than stock shift points. Driveability and a fat powerband are what I'm searching for; not sure if I'm gonna stall it or not.
Old Apr 10, 2005 | 03:44 PM
  #36
vette40th's Avatar
CC 305 is good, Hot Cam is good. Basically stay with 210-220 duration on intake and up to 230 MAX on exhaust with a lobe sep of 112-114, lift 510-530.
Old Apr 10, 2005 | 04:02 PM
  #37
JBird33's Avatar
I was thinking of doing the hotcam, but from the way some of the people in here are talking, it got me thinking that perhaps for my application the hotcam was a hair on the big side....maybe not though.
Old Apr 10, 2005 | 05:29 PM
  #38
Beyonce Knowles's Avatar
Hotcam is usually considered on the small side, but for lots of people its just right. CC305 is said to be a cam for automatics, 306 for A4's.
Old Apr 10, 2005 | 05:37 PM
  #39
JBird33's Avatar
305 for autos, but 306 for A4s, eh??
Old Apr 10, 2005 | 07:25 PM
  #40
Zachz28's Avatar
What kinda of shift point would you use on a 224/230 with stock heads?
Old Apr 10, 2005 | 10:10 PM
  #41
whatsup's Avatar
no dyno time here but with the 224/230 and Crane 10308 springs I shift at 6000...it just feels like it hits a wall much higher.
Old Apr 10, 2005 | 10:16 PM
  #42
madwolf's Avatar
With a 224/230, you should be shifting at around 6400-6500 for best track times. If it's hitting a wall after 6000, you have problems. (springs, ignition, etc)
Old Apr 10, 2005 | 10:25 PM
  #43
turbo_Z's Avatar
I agree. I dont spin my stock shortblock up that high for fear I wont be driving it home later but have seen a 3 mph increase shifting from 5500-6000.
Old Apr 10, 2005 | 10:31 PM
  #44
bpipe95's Avatar
ok answer me this 95 m6 stock rear gear hot cam kit what is a good starting point for shift points?
Old Apr 10, 2005 | 10:33 PM
  #45
madwolf's Avatar
There are a few people on this board who got really good times shifting the hotcam at 6500, but 6200-6300 should be fine.
