please help want to kill truck lol wont run
Old Feb 27, 2004 | 01:22 PM
lt1s10on20's's Avatar
please help car wash now not running
well just finished painting my truck started it up ran perfect went to the car wash washed truck and motor went to leave and it wont start had to be towed home did i ruin the opti ? do i need to wait a few days and it will start ? the opti only has 900 miles on it same with cap and rotor , plugs coil and wires have 150 miles on them this is a show truck and hasnt been driven much since the swap here is what i am working with a 1995 vette lt1 4l60e in a 99 s10 reg cab short box tubbed and 4 linked on 20's , my opti is from autozone and they said i have a 1 year warranty i belive but thats alot of work to replace any other ideas of what could have happend it ran perfect before i washed the motor thanks in advance guys
DJ
Old Feb 27, 2004 | 03:51 PM
ok i tested a few things with one of those inline spark testers i bought a new coil and still no spark from the coil could the water have made the icm crap out ? does no spark from the coil mean thats whats next to check i did the check in the book to test voltage to the wires on the icm and they read 7.3 volts it says if under 10 something is wrong but what would washing the motor have to do with that messing up i ordered a new icm should be here in the morning man nothing but trouble with this motor
Old Feb 27, 2004 | 06:22 PM
anyone??? i was just reading and it looks like the opti reads its signal and sends it to the emc which sends it to the icm whichs feeds the coil how can i check if the opti is sending signal to the ecm?
Old Feb 27, 2004 | 06:38 PM
gb95zconv's Avatar
Get a hairdryer , unplug connectors and dry everything out good. If you have a vented opti it will most likely dry out and youll be fine. If its non vented you may have to remove it and take the cap off to dry it out. Never put water on an lt1....I guess you know that now.
Old Feb 27, 2004 | 06:42 PM
bad opti would cause no spark from the coil ? and do these normally dry out ? it is a 95 vented one only 800 miles on opti we tryed blowing some air thru the vent hole to dry it out ill try the hair dryer tommorow
alphaauto
Jan 22, 2015 08:02 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
