Please Help W/ Fuel Injectors!
Old Jan 14, 2006 | 09:51 PM
SMO Q's Avatar
Im trying to install the ford racing 24# injectors on my 95 z and I noticed that the stock injectors when pushed into the fuel rail go all the way into it until they are seated flush against the inside of the hole. in order to get the ford injectors to work with the stock retaining clips they have to be backed off the seat inside the holes. Is this how it is suposed to be or do I need different retaining clips, or do I have the wrong injectors? I would think that the injectors would have to be pressed in all the way to work correctly and not leak. I ordered the injectors from summit in the mustang section, the only part # on the box is M-9593-A302. please help.
Old Jan 14, 2006 | 10:05 PM
OBE1 95Z28's Avatar
Re: Please Help W/ Fuel Injectors!
The injectors don't need to be bottomed out in the intake manifold, as long as the o-rings are below the intake surface they will seal fine. Be sure to apply a small amount of motor oil to the oil rings to allow them to slide into place without getting damaged.
Old Jan 15, 2006 | 12:10 AM
Jameslt1TA's Avatar
I just installed some ford 36#s and i though the same think you did...but i didnt worry i just left it backed out a bit and used the retaining clips. Btw why are you putting new injectors in the stock ones are good for at least 350 rwhp or so.
Old Jan 15, 2006 | 03:43 AM
96capricemgr's Avatar
I would also recommend tuning for those, while they are rated the same as stock they are rated at a slightly different pressure. Hope these were to replace faulty stockers or in preparation for a dry shot otherwise it was pretty pointless.
Old Jan 15, 2006 | 08:50 AM
SMO Q's Avatar
Yes Im doing nitrous this summer and I had one dead injector and another was leaking. so I wanted to replace them. thanks for the help guys.
Old Jan 15, 2006 | 09:19 AM
The flow difference is insignificant. The stock injectors are programmed as 24.92 #/HR. A 24# injector rated at 2.7bar (39.15psi) will flow 25.30 at 3 bar (43.5psi). I've run the SVO's with no "tuning" and there was no measurable changes in the long term fuel corrections. I also switched to the SVO's to run a dry nitrous system. The stock injectors wil have problems with the elevated pressure of the dry shot.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
