Please help - opinions needed
Old Nov 14, 2009 | 02:25 PM
Queens94z28's Avatar
Hello,
I just purchased a new lt1 shortblock from someone. It has never been used and was on a pallet covered in plastic. It definitely needs a good cleaning. Can someone please help me and let me know the correct way to go about getting this into running shape. This is an OEM shortblock that has been sitting around since 1997. Crank turns easily. All I have done at this point is put it on my stand and oiled it up real well. Should I remove the main caps and check the bearings? Can I just put it back together after that with some assembly lube and retorque the bolts to spec?
All help is appreciated. Would like to avoid going to a machine shop if necessary. Plans for this block are a mild AI or LE package.
Pics below. Thanks!!
Old Nov 14, 2009 | 03:13 PM
Not sure why my pics arent working. They are in my photo album here if anyone can take a look.
https://www.camaroz28.com/forums/members/queens94z28-57450-albums-shortblock-416/
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
