Please Help My Lt1!!!!
Old Sep 30, 2005 | 01:52 PM
brizzle's Avatar
Hey, I have a 1995 z28 and for the past 3 or 4 months every time i drive any more than 5 miles my engine coolant light comes on and my engine temp. goes way up pretty quickly and i eventually have to turn the heat on full blast just to keep the engine temp. down (and i live in Miami so heat on high is horrible in this weather). I know i'm not low on coolant because i just got it flushed and refilled about one month ago. I've taken the thing to 3 different mechanics all of which claim "they fixed it". But, obviously, none of them have fixed it at all. Can anyone provide me with any suggestions at all as to what is wrong with it????? I'm obviously an amateur when it comes to dealing with engines, but any information or suggestions at all will be much appreciated. Thanks alot....
Old Sep 30, 2005 | 02:56 PM
wrd1972's Avatar
Re: Please Help My Lt1!!!!
I have a 160 degr4ee thermostat and used to have the hypertech power programmer. When the custom tuning was in the PCM tempertures were perfect. One time I put the GM tuning back in for service and forgot to remove it and it ran hot as hell, near boiling.
Are you maybe doing somthing similar?
Old Sep 30, 2005 | 03:09 PM
WestCoast96Z28's Avatar
Don't take this as a smart a$$ question, but do you hear the fans turning on? I had a similar problem and it turned out to be a bad control board for the fans. The engine was reaching the temp to turn on the fans, but they never got turned on. Had to do the same thing..pull over and wait.
Old Sep 30, 2005 | 03:13 PM
Mean Green's Avatar
have you checked the fluid level in both the radiator and the resevoir?
also if it comes close to overheating and you're not sure the fans are on. it's actually better to turn the AC on, because that will turn on the fans instantly.
Old Sep 30, 2005 | 03:16 PM
faded93bird's Avatar
Also a new cap could work wonders.
I bought a new gm unit and it helped keep temps down.
Faded
Old Sep 30, 2005 | 03:43 PM
brizzle's Avatar
thanks alot for the adivce, i'll see if i can get it worked out. Anyone with any other ideas feel free to add them....
Old Sep 30, 2005 | 03:54 PM
Z95m6's Avatar
did it have this problem before you took it to get the coolant flushed?
Old Sep 30, 2005 | 05:55 PM
brizzle's Avatar
yes, i had the problem about a month before i got the coolant flushed, and it made it very difficult for the coolant to be flushed and refilled, it took a really long time. They suggested that i get a new thermostat, which i did, but problems still persisted
Old Oct 1, 2005 | 10:36 AM
Cepan's Avatar
There may be air in the system.
If you have the small brass valve on the hose coming from the cap area you can relieve the air pockets.
Get a Haynes manual or talk to a GM mechanic about this.
It's a dumb system but if there is ANY air pockets in the coolant system the car can run really hot.
Also make sure the overflow is filled and get a new radiator cap.
Cepan
Old Oct 1, 2005 | 10:41 AM
DugRat's Avatar
Your radiator is probably not flowing like it should, pull your cooling fans while it is hot and feel the radiator, when I did this on mine half the radiator was cold when the temp was about 200. You might need a new radiator
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
