Please help me with my bad idle problems
Old Jun 23, 2003 | 05:18 PM
94DROPTOPZ28's Avatar
I need some help with my bad idling problems on my car. When you first start up the car and drive it the cars runs fine, but once the car gets warmed up the problem starts. The car has a new coil, new plugs and wires,fuel pump and fuel filter. I have cleaned the throttle body and have already checked for vacuum leaks, also I have scanned the O2 sensors and they all seem to be reading fine. Can anybody give me any suggestions on what to check next???
Old Jun 23, 2003 | 07:31 PM
slopokrodrigez's Avatar
I didn't notice you checked the EGR for leaks or sticking. I also didn't notice if you checked the fuel pressure regulator for a hole in it. check the vac line to see if its wet. While your at it check your fuel pressure with the vac line connected and with the vac line disconnected and plugged.
Old Jun 24, 2003 | 05:31 AM
I also just replaced the EGR, and the vacuum line is not wet and I checked the fuel pressure with the vacuum line on and off. I also took of the IAC and cleaned that and it still hasn't fixed the problem ....
Anymore suggestions???
Old Jun 24, 2003 | 01:34 PM
95 Silver TA's Avatar
I am having very similar problems too with no SES light or code. I was told it could be the Opti or since I just changed my Pump it could be vapor lock (mabee I crimped a line)....I have not figured it out yet but mabee someone else can shed some light on this.
TTT.
Claude
Old Jun 24, 2003 | 02:29 PM
thad's Avatar
I have a problem very similar too...any help would be appreciated!
Old Jun 26, 2003 | 04:04 AM
TTT
Old Jun 26, 2003 | 04:12 AM
predator's Avatar
it could be the evap canister or purge valve and purge soilinoid (sp)....mine did that another problem is carbon buildup on the back side of the valves
Fatdog2
Feb 13, 2015 08:19 PM
edman
Jan 25, 2015 02:41 PM
Britbilly
Jan 7, 2015 08:49 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
slothgrant
Aug 22, 2002 03:01 PM
