Please help me with an electrical problem! QUICK!
Old Apr 19, 2003 | 04:34 PM
twells's Avatar
Lightbulb Please help me with an electrical problem! QUICK!
i just need to know what fuses should be drawing power with the car completly off. i am having something draw down my battery and i am not sure what it is. i used a voltmeter to check all of my fuses and with the car off, i have power to the "abs bat" fuse and the "pcm fuse" should these have constant power?
thanks guys
thomas
Old Apr 19, 2003 | 06:04 PM
Laymaster's Avatar
I'm pretty sure the PCM fuse should have power...anyway TTT for ya.
Old Apr 19, 2003 | 06:12 PM
Wild1's Avatar
Check for voltage drop another way. Disconnect the battery positive and connect the voltmeter there set to Amps.
You should be getting milliamps registering. Otherwise something is flowing. A friend will come in handy here. Remove and replace each fuse one at a time. When you see the amps suddenly drop with a specific fuse, you have found the suspect circuit. Then check that circuit and components for good connections and grounds and integrity of the wires (rats like to chew on the insulation).
When you find the suspect circuit let us know and we'll go to the next step.
Good luck.
liamcg97
Nov 25, 2019 05:55 PM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
Jazsun
Dec 29, 2014 12:14 PM
