please help identify this wire...
Old Jul 9, 2003 | 12:43 PM
LWillmann's Avatar
I went outside at lunch to test my fans following shoebox's directions of disconnect the connector (C100 I think he calls it).
When I was doing this, I notice that where the wiring heads back down the fender well near the PCM there is a single red wire with a connector on it, but it's not connected to anything. This single wire is very close to the two weather tight connectors on the fender well.
I don't have a picture handy, but this wire is on the PCM side of the harness rather than the battery side if you follow me.
Any ideas?
Oh, and I attempted to ground both the green and blue wires to the body and nothing happend with my fans. Did I do that wrong? I have not had a fan related SES light, but I was thinking I would install a manual fan switch and wanted to make sure the fans turned on properly. I have never heard them at all, but the car never seems to over heat.
Am I supposed to ground the PCM side of the connector or the battery side of the connector?
I had the key on, per his instructions in other posts.
Old Jul 9, 2003 | 02:38 PM
sssalah's Avatar
If I'm not mistaken the gray wire thats not connected is the fuel pump priming/testing wire. When you put 12v to it, the fuel pump starts.
Old Jul 9, 2003 | 02:41 PM
Grey on pre 1996 and red after that. It is the fuel pump prime wire.
Old Jul 9, 2003 | 02:53 PM
LWillmann's Avatar
Thank you for the info... I had heard that there was such a wire...
Hey shoebox (hoping you see this again),
Did I do something wrong on my fan test?
Old Jul 9, 2003 | 03:59 PM
You ground the forward connector end, not the pcm side. You should not need the key ON on the 1996-1997s. The relays are constantly powered (not so on pre-1996). Use the ground terminal on the RH shock tower for convenience.
cjamen
Jul 27, 2015 12:48 PM
Latronaxe
Jun 10, 2015 02:08 PM
detroit1994z28
Apr 19, 2015 08:11 PM
taner
Advanced Tech
Nov 9, 2003 09:30 PM
Jeff H
Classic Engine Tech
Dec 1, 2002 02:35 PM
