Please help, How can I get rid of this "SKIP SHIFT"
Old Feb 17, 2005 | 01:53 AM
keng's Avatar
Hey guys I just picked up a 97 Z and need some info on how to get rid of this skip shift.
Old Feb 17, 2005 | 02:05 AM
disco192's Avatar
Re: Please help, How can I get rid of this "SKIP SHIFT"
welcome to the boards.
You can buy a skip shift eliminator from www.thunderracing.com, or you can do it manually.
There is a good guide at http://www.ls1.com/link_cags.html
Its not a tough fix. I have mine tuned out in my PCM, but you can do it this way.
Old Feb 17, 2005 | 08:18 AM
1-bad-z28's Avatar
when i first got my car i just unplugged it from the transmission. Never any side effects.
Old Feb 17, 2005 | 09:04 AM
Z95m6's Avatar
disco pretty much took care of the methods. Just a note if you do either of the two methods he showed in the links you will still have the skip shift light come on, it just won't actually make you skip shift. The only way to get the light to go out besides pulling the bulb is to have it programmed out of your PCM.
Old Feb 17, 2005 | 12:04 PM
keng's Avatar
How do you get th skip shift programmed out. So even if I buy the elminiator it will still cause the light to come on. Who can program it out of the computer?
Old Feb 17, 2005 | 12:14 PM
Z95m6's Avatar
Well you may be able to find someone in your area that can program it out for you for free if not you would have to send it to madwolf or pcm4less which would be expensive for what you want to have done. I would wait for a pcm program unless you can get it done for free from someone local or until you have more mods to justify the tune.
Old Feb 17, 2005 | 12:17 PM
birdman1's Avatar
Just uplug it, and wrap the end of the wire good with black tape. so what if the little light comes on in the corner of your dash? Mine's been that way now for 2 years, best thing I did to that car.
Old Feb 17, 2005 | 12:21 PM
TraceZ's Avatar
If his car is a 97 with OBDII wont just unplugging it and wraping it with tape signal a SES light? I could be wrong.
I'd recommend getting the eliminator as mentioned above. It fools your PCM into thinking it is still hooked up.
Old Feb 17, 2005 | 12:50 PM
birdman1's Avatar
Ok, sorry, I don't know if the newer ones get mad, mines a 94
marlar98
Sep 19, 2015 07:53 AM
Aug 5, 2015 08:35 AM
jmadoll
Jun 10, 2015 04:41 PM
Apr 16, 2015 09:57 AM
'01BlackZ
Mar 21, 2002 01:47 AM
