please help with a final cam decision
Old Nov 15, 2003 | 04:51 PM
97Z-M6's Avatar
well i need some help making a choice. im having loyd port a set of heads for me. but my problem is that i dont know what vam to get. i like the 847 but it seems that you have to spin it pretty high, and that what i dont want to do. i want a cam that wouldpeak at 6300 or so but no more that 6500. but i want the alot of lope, do i was think mabye get the ex236/242 on a 110, i know the ex grinds peak earlier than say the 306, but maybe the 110 will put the peak HP up there a little higher around 64 or 6500.
honestly i want to make all the hp i can, but i want the lope and im willing to sacrifice a few hp for the sound. i would like to hit the 400 mark.
i know ive ask alot of cam questions, and i cant promise the this will be last, but thanks for the help in advance. i just dont want to sin the stock bottom end that high.
but if you have an idea of a good cam to meet my goals, let me know which one and why.
note: i have a 306 right now on my table, and i can send it back and get it on a 110
thaks agian
Old Nov 15, 2003 | 06:02 PM
96LT14u2Nv's Avatar
i like my 230/236 on a 110 LSA. up to you. the 847 cam is a great cam for a six speed though. all i have seen use it are running 4.11 or more gear though.
Old Nov 15, 2003 | 08:09 PM
97Z-M6's Avatar
anyone else.
Old Nov 15, 2003 | 09:08 PM
97WS6SCharged's Avatar
That 306 will definately give you some sound. I think it peaks out a little sooner than you want though (I could be wrong). I was looking at Comp's NX276HR grind for my car. I know it's for a N2O or blower car, but it should work well with a NA car as well. It specs out to:
224/236 duration @ .50
.502/.520 inch lift @ .50 w/1.5 rockers
.535/.555 inch lift @ .50 w/1.6 rockers
on a 113 lobe sep (I was going to have it ground to 114)
Supposedly good from 2000-6000 RPM so it should rev to 6300 and still be pulling hard.
Good luck.
Old Nov 15, 2003 | 11:18 PM
97Z-M6's Avatar
thanks for all the suggestions.
i would like something with some what of a steep ramps to help out under the curve.
Old Nov 15, 2003 | 11:27 PM
96 WS6's Avatar
I still like the 847... The lift is nice compared to the cc306. Look at Atljar videos... That's all I need to see haha that thing sounded SOOOOO SICK on the dyno. For you non-Californians, that means GOOD!
Old Nov 19, 2003 | 09:24 PM
Just out of curiosity, and the fact that I'm too lazy to look for the cam right now, but what are the specs @ .50 on the 847 camshaft?
Old Nov 19, 2003 | 09:35 PM
97Z-M6's Avatar
234 242on a 112 with 539 lift int. and 558 lift exh. with 1.5 rr
Old Nov 19, 2003 | 09:42 PM
Kraest's Avatar
Retired
First of all, you should have had Phil (SkarodoM) port your heads for you.
Secondly, if you're getting some nice heads (no idea who lloyd is), you're going to be kicking yourself later if you don't get enough cam.
I'd go with a CC306 MINIMUM if I had some really nice heads that flowed a crapload of CFM with awesome port velocity.
Unlike an automatic with a huge stall, with a 6-speed, your driveability won't be sacraficed no matter which cam you go with.
Mike
Old Nov 19, 2003 | 09:50 PM
97Z-M6's Avatar
Mike
well loyd is known on the board as nightrain66. and he turns out great heads.
but anyway on the cam i have the opinion as you 306 at a minum . but i sure am leaning toward the 847 on a 110
Old Nov 19, 2003 | 09:52 PM
rskrause's Avatar
Moderator
What is the CR on this motor and what tranny/rear end will you be using? What is the main use for the car?
Rich Krause
Old Nov 19, 2003 | 09:58 PM
97Z-M6's Avatar
the CR will end up at 11.25 or 11.5 the car has the stock t56 (soon to be rebuilt) and stock rearend for now. hope to get a 12 next summer . it is my daily driver and will not see much track time at all till spring. but when the cam and things go in i do have a honda to drive back and forth to work.
Old Nov 19, 2003 | 10:03 PM
rskrause's Avatar
Moderator
I think the 847 is not a bad choice for you, but you will need the right supporting parts (pushrods, rockers, springs) and might be happier with it with 4.10's than with stock 3.42's. May not make enough vacuum for the brakes to work right in traffic though.
Rich Krause
Old Nov 19, 2003 | 10:04 PM
ImportsRsloths's Avatar
Another vote for the 847!
Old Nov 20, 2003 | 01:37 AM
Man, what page is that at the bottom of? That's the age old way to select a cam, go to the bottom of the page and then find one that's even bigger. Anyone know how much valve overlap that thing has on the 112 grind? Or better yet, a 114 grind?
pimpss96
Feb 12, 2015 01:28 PM
ChrisFrez
Dec 7, 2014 06:01 PM
Chris 96 WS6
33
Sep 3, 2002 09:48 PM
madman69
Aug 18, 2002 03:58 PM
