Please help. F-body LT1 Install suggestions?
Old May 17, 2006 | 01:51 AM
pit's Avatar
pit
Question Please help. F-body LT1 Install suggestions?
Doing the whole drivetrain swap from a wrecked F-body to B-body (Impala), both 95.
Just wondering what you guys recommend changing/replacing (gaskets and such) on the F-bod LT1 before I drop it in.. You Z-guys have the Exp. with these motors so I ask your collective knowledge. The Fb LT1 has 43k on it,and is a 6spd if that helps.
Thanks in advance
Old May 17, 2006 | 02:23 AM
sssalah's Avatar
Re: Please help. F-body LT1 Install suggestions?
If it doesn't show any leaks then there's no need to change anything. Obvious places for leaks are the intake manifold, front cover and seals, rear seal and pan seal.
That 6-speed should be plenty of fun with the impy!
Old May 17, 2006 | 06:28 AM
camaroz2866's Avatar
its only got 43k on it all of the gaskets and such should be fine
30thZ4C
Dec 26, 2014 05:09 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
Brent94Z
Mar 21, 2002 04:44 PM
