Please help with electrical issue
Old Jan 20, 2005 | 12:24 PM
kcshaner's Avatar
Angry Please help with electrical issue
My 95 Z28 is having some serious electical issues issues that I need help with. The blinkers barely work, and when they do, the usually just turn on with dim light and don't blink, also a few times my car was not starting so I had to keep jumping it so I purchased a new alternator.....It worked for about a day then died again (had to jump it). So two days ago I install a new battery....the blinkers still do not work, it died yesterday and my charge is in the red at all times. What can I check that could be causing my problem? Any ideas?
Any help is appreciated
Old Jan 20, 2005 | 12:30 PM
Dreamin69Dragy's Avatar
Re: Please help with electrical issue
Hey, new to forum but i actually had a simular problem the other day, mine turned out to be a bad alternator wire, just some insite maybe thats the case i dunno
Old Jan 20, 2005 | 12:39 PM
kcshaner's Avatar
Thanks....how would I check that? Which wire is it?
Thanks!
Old Jan 20, 2005 | 01:55 PM
AZ2ENVY's Avatar
Ok ive fixed this problem before. Here it goes..............................
When you pop your hood , Theres a wire grounded to the support
brace on the right hand side . If you look on the brace on the drivers
side of the radiator closest to the front of the car its a ground wire.
Make sure its as tight as can be and its touching BARE metal , Not
painted . This will take care of the problem Any other question just
PM me
Old Jan 20, 2005 | 02:06 PM
kcshaner's Avatar
Very helpful, and very nice of you to offer help. I will try these things tonight and see what happends!
Old Jan 21, 2005 | 04:03 PM
Here4Beer's Avatar
Sounds like a grounding issue. Jack up the front left and get under the engine, oh yea use a jack stand OK. Should be a braided ground wire attached to your engine block. Use an Ohm meter and check for resistance from there to your chassis somewhere metal.You should get a reading. If you have a lot of resistance you could have corrosion somewhere in the ground circuit. Also make sure your battery terminals are clean and shiny.
Old jet fighter fixers never die,they buy Camaros!!
eanhl2004
Apr 4, 2015 12:01 PM
Gtpguy
Jan 26, 2015 04:50 PM
BMX Dad
Jan 23, 2015 07:00 PM
Queens94z28
Dec 20, 2014 09:11 PM
