PLEASE HELP!!! can i put black RTV silicone on header to hold in place while install?
Old Jul 19, 2004 | 04:42 PM
TexasTechTA's Avatar
PLEASE HELP can i put black RTV on header gasket to hold in place while install?
can i put black RTV silicone on the header gasket and glue itto the header so it stays in place while I install it. i tried sliding it in with the 2 outter bolts and that did not work please help?????
Old Jul 19, 2004 | 04:48 PM
Dave89IROC's Avatar
Re: PLEASE HELP!!! can i put black RTV silicone on header to hold in place while install?
use the kind of rtv that has copper in it, then put it on both sides of the gasket, then. if the bolts stay tight, the gasket will never leak
Old Jul 19, 2004 | 04:49 PM
is that copper RTV for header gaskets?
Old Jul 19, 2004 | 05:39 PM
please will the copper stuff be okay???
will it burn the gasket?
Old Jul 19, 2004 | 05:42 PM
96TurboTA's Avatar
I've used the copper seal to do this. works fine, and won't leak. A thin layer of grease will work as well.
Old Jul 19, 2004 | 06:16 PM
never mind i think i got it on good dry, anyway whats ther torque specs for header bolts?
I thought you tighten them as much as you can
Old Jul 19, 2004 | 06:49 PM
Dave89IROC's Avatar
yup
and keep checking them, check them tommorrow, next week and then the week after that, if they are tight that last time, quick check them every month
ANDYZ28
Dec 29, 2014 09:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
