Please help with brake problems
it started with the low trac light flickering, the ABS inop light coming on and the parking brake light staying partially lit when the brake was down. i pulled the ABS fuse and the low trac light went out but the abs inop lights still on (obviously) and the parking brake light is still on. brakes work fine, just no ABS, any ideas on whats going on here??
brian
brian
thanks rob, i know the battery is fine, but i will check the other areas when the weather clears up here. any chance it may be a bad ground or something? maybe the relays shot?
brian
brian
brian
brian
cool, ill check them. it literally happened overnight, which was weird. and it coincided with my alternator problems (you may recall) which i remedied and are working perfectly. this car has had so many gremlins its unreal! thanks again for your help.
brian
brian
Magenta_Hearts
Mar 25, 2015 10:24 AM
dluna333
15
Mar 13, 2015 12:30 PM
