PLEASe help asap, everyone inside :(
Old Dec 29, 2003 | 08:59 PM
Green G0blin's Avatar
i have some big problems guys, hope you can help.
i have a 1996 formula. bought it with 71K miles on the dial. i then proceeded to buy some 93 lt1 heads that were port and polished by another board member, they were a mild port job, nothing major, i also bought new pushrods, and the lt4 hot cam kit. i had a local mechanic install in it in my car, as i was going home, not even 15 miles, the car started acting up on me and turned off. i thought it was the battery so i bought a new battery, errr, it wasnt the battery. i would turn the car on and when i would try to drive it, it would turn off, so i thought it was the opti, bought a new opti and coil. errr still not the problem so the mechanic that put the opti for me told me i had low compression in cylinders on the passenger side. so i take it back the original mechanic and he tells me this.
i had 3 messed up lifters, and 3 messed up pushrods. he told me cus i didnt have no guideplates to keep the pushrods and 3 of them got messed up.
my question is, do i just buy some guideplates and buy the same pushrods? cus the local speedshop told me i had to get some magnum comp cams pushrods ($160) to use for the guideplates? are they tryign to jip me. or they are telling the truth? as far as the lifters should i buy some other ones, do i need upgrade, or can i get some stock lifters that you guys that did the switch have laying around? i really need help, i bought this car back in febuary, and i used it for a total of 2 months this year i really want my beast at the track smoking some 'stangs and ricers please any help is greatly appreciated, please just post opinions, and those who have done the mods i have done, your opinion and help is greatly appreciated! if any more insight email me at
GreenGoblin956@yahoo.com
thanks, i hope i get this fixed.
by the way, any of you have some spare lifters laying around? i need 3 of them
Old Dec 29, 2003 | 09:07 PM
Comp Cams OE Replacement Hydraulic Roller Lifters, SB Chevy & LS1
Comp Cams Hi-Energy hardened pushrods, 7.200 (OEM Roller - Factory Length)
thats my cart at thunderracing.com
do those parts sound right? its just some mildly ported heads with the lt4 hot cam.
Old Dec 29, 2003 | 09:20 PM
viperkiller's Avatar
you really should use guide plates with that much lift.
stock pushrods and lifters will work with the "little" cams such as the hotcam. i'm running a 545 555 lift with stock lifters and pushrods.
if your in cen tx i have a couple extra sets i would let you have a few.
Old Dec 29, 2003 | 09:23 PM
hook me up! i am not in central texas, more like south texas, near south padre island.
thats what i was thinking, i think the local speed shop (since there iso nly 2 in the area) was trying to get me to buy the expensive pushrods
greengoblin956 on aol
so we can talk!
Old Dec 29, 2003 | 10:01 PM
sent you a priv message
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
