Please HELP...Anyone...
Old Sep 12, 2005 | 08:19 AM
musclecar's Avatar
I have a 95Z A4. I rebuilt an LT1 from a 94 Corvette, put a small cam in it and put it in the Camaro. The car runs great but keeps lighting the SES light after running for a few minutes. The code it is throwing is 29 - Secondary Air Injection Pump Circuit. Where do I start to fix this? I don't know much about these computer cars and I've read that this code can be any thing from the EGR to low vacuum somewhere. Can someone PLEASE tell me where to start or what to do with this thing? I need this car to be fixed very bad.
Any help is greatly appreciated.
Thank you,
Tony
Old Sep 12, 2005 | 08:21 AM
Re: Please HELP...Anyone...
Check the AIR pump fuse in the underhood fuse/relay panel. There was a recall several years ago due to AIR pump problems.
Old Sep 12, 2005 | 03:31 PM
musclecar's Avatar
Thank you for the response. The fuse was blown. I can't drive the car right now to see if it blows again, but if it does, any idea why? Is there anything that I can do to correct whatever is causing this? Thank you again for your help.
Tony
Old Sep 12, 2005 | 03:42 PM
Black1995Z's Avatar
Tony
Mine was clogged and caused it to blow over and again.
Old Sep 12, 2005 | 03:46 PM
Tony
That was why the recall was done. The AIR pump draws too much current and blows the fuse. If your car has not had the recall done, call a dealership and schedule to have it done. It is free. If you give them your VIN, they can tell you if the work may have already been done.
Product Emission - Air Injection Reactor (A.I.R.) Pump System Failures #99083
99083 -- Air Injection Reactor (A.I.R.) Pump System Failures
1995, 1996, 1997 Chevrolet Camaro and Pontiac Firebird Model Vehicles
Equipped with 5.7L Engine (RPO LT1-VIN Code P)
Condition
General Motors has decided to conduct a Voluntary Emission Campaign involving all 1995, 1996 and 1997 Chevrolet Camaro and Pontiac Firebird model vehicles equipped with 5.7L (RPO LT1-VIN Code P) engines. The Air Injection Reactor (A.I.R.) pump emission control system on these vehicles may fail to operate and cause the Malfunction Indicator Lamp (MIL) to illuminate. This condition may be due to corrosion of a solenoid internal to the A.I.R. pump.
Correction
Dealers are to install a new A.I.R. pump assembly kit that is designed to protect the A.I.R. pump system from failing due to internal corrosion.
Vehicles Involved
Involved are all 1995, 1996 and 1997 Chevrolet Camaro and Pontiac Firebird model vehicles equipped with 5.7L (RPO LT1-VIN Code P) engines and built within the following VIN breakpoints:
Year Division Model Plant From Through
1995 Chevrolet Camaro Ste. Therese S2100001 S2229521
1995 Pontiac Firebird Ste. Therese S2200001 S2256723
1996 Chevrolet Camaro Ste. Therese T2100001 T2166869
1996 Pontiac Firebird Ste. Therese T2200001 T2232760
1997 Chevrolet Camaro Ste. Therese V2100002 V2160181
1997 Pontiac Firebird Ste. Therese V2200001 V2232666
Old Sep 12, 2005 | 04:03 PM
Z95m6's Avatar
If you don't care about the air pump you can just reach down and unplug it. Then you won't get an SES light anymore as long as your fuse is good.
Old Sep 12, 2005 | 06:32 PM
musclecar's Avatar
Thank you again for the responses. I called the local dealer and there is in fact, an open recall on my car. They said to bring it on over...lol.
Tony
